Question about Transmission & Drivetrain for GMC G1500
96 Caddi sedan De Ville
Just changed the transmission filter and gasket replaced fluid and now the car will not go into reverse??? HELP
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Put the car into drive have someone in the car holding the brake peddle with the ebrake on and check the fluid level. Reverse requires more fluid.
Posted on Apr 02, 2014
Filter de aceite de la trans mission
Trans filter is in the bottom. Drain fluid from the transmission pan and remove the securement bolts for the pan. Replace the filter, put the pan back on with new gasket, and refill the transmission with same amount of fluid removed.
Sep 24, 2014 | Cars & Trucks
Where is transmission filter located in 2001 mitsubishi diamante located and how do i change it?
transmission filter in the bottom of transmission bolted to valve body.you need a large drain pan.place drain plug under transmission oil pan.remove transmission oil pan drain plug.let all transmission fluid drain out then screw back drain plug in oil pan.then you need to remove transmission oil pan then remove filter and replace pan gasket also.make sure you have right amount transmission fluid on hand.buy extra because if you short of fluid you cant drive car if fluid level too low.make sure you get the right amount fluid.torque pan bolts to 96 inch pounds.
Nov 10, 2011 | 2001 Mitsubishi Diamante
So..I'm a female nerd!! How and can I change the transmission fluid myself? It is a 96 chevy blazer 4 wheel drive
It's not too hard at all. You'll need a decent size drain pan. You'll want to remove all but a couple of the transmission pan bolts on the bottom of the transmission. Let the fluid drain out as you loosen the last couple bolts. Once most of the fluid has drained out, remove the last couple bolts and let the pan done and pour out the remaining fluid, discard the old pan gasket. I would also replace the transmission filter, the new filter should have a new pan gasket with it. Remove the old filter, install the new filter, use some gasket cement to glue down the new gasket to the pan and reinstall and fill with new fluid. I would also check your transfer case fluid level, the transfer case is behind the transmission.
Nov 18, 2010 | 1996 Chevrolet Blazer
Where to check transmission fluid on 93 Cadillac De Ville Northstar V8? We are getting a ''service transmission'' message, but we CAN NOT find the transmission dip stick. My daughter has the same car &...
it should be right under the air filter . or in the area. u will probly have to remove the air filter to see it its a black cap about 2inches in diamator.
Mar 08, 2010 | 1993 Cadillac DeVille
How to change a fuel filter on a 1989 Cadillac De ville?
remove the filter with a special removal tool that can be obtained at Auto Zone
Feb 28, 2010 | 1989 Cadillac Sedan DeVille
Transmission dilemma
if you do, be sure to change the gasket on the pan too.
Feb 08, 2010 | 2006 Pontiac Grand Prix
I have a 2001 Saturn LS with the 2.2 Liter engine. The problem is the transmission shifting very hard, and also when shifted from parking to either reverse or drive it kiks in very hard.
Trying changing your transmission fluid and filter. The fluid gets gummed up and causes very rough shifting. It may also be low as well. I would suggest a full back flush where all fluid is pulled out of the system including the torque converter whereas a simple fluid and filter change will not do that. Also, there is a transmission fluid filter on the transmission lines, it looks very much like an oil filter. I believe that will greatly help your problem.
Aug 29, 2009 | 2000 Saturn Ls 4dr Sedan
1999 gmc suburban rpms go up but car does,nt go any faster
Have you checked the transmission fluid level?  Also, have you changed the transmission filter?  I would definately do these two before I would take it to a shop.  A typical transmission filter/gasket kit costs about $10-15 for that truck.  And the transmission fluid will run around $2-4 per quart.
Changing the filter is easy.  You will just take the transmission pan off and then pull the filter out, replace the filter, and then replace the pan gasket.  Then bolt it all back up and fill it with fluid!  It's that simple.
Jan 23, 2009 | 1999 GMC Suburban
96 Taurus with cold transmission problem
you will need a new trans soon
Dec 09, 2008 | 1996 Ford Taurus
1997 De Ville Reverse lights do not work
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
Oct 14, 2008 | 1997 Cadillac DeVille
Vehicle Parts & Accessories Logo
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
