Question about Car Audio & Video
Ok. Just got off the phone with the shop. Here's what's happening. They program the EWS and the car starts and runs. The minute they turn it off it won't start up again until they program the EWS again. Then it starts. He's unsure of why this is happening and is seeking outside help. If anybody knows what the problem might be I'd appreciate the input very much before it costs we an arm and a leg to diagnose. You can text or call me at 847-812-7749 Thank you in advance Michael
  • 2,433 Answers
The wire that has constant power to it is broken or unhooked. It will loose its program everytime the vehicle is shut off.
Posted on May 31, 2017
I have a 2003 bmw x5 and it wont crank. All the light and everything works properly but when i turn the key over there is no noise...nothing. I can take the key in and out and keep trying and it will...
Starters have a solenoid that can go bad. I don't know for sure on that model car but most cares now have a rod that runs down through the steering column and activates an electrical box. follow your wires under the dash and see if they run into a box attached to the column.
Feb 27, 2015 | 2003 BMW X5
Programing anew key
BMW Multi Tool is known as one of the best car key programmers for BMW vehicles ever since OBDII tools were available in last century.
It has multi-function: key programmer, odometer correction, eeprom read and write, Synchronization Codes, and so on.
BMW Multi Tool includes forth parts, hardware device, dongle, programmer, software. Before running software you must connect dongle and hardware device to computer.
Newest version is V7.0 BMW Multi Tool V7 0 for CAS1 3 and EWS Powerful Than AK300
May 09, 2014 | 2001 BMW 325
Error code 2f44 bmw won't start tried to clear but comes back after every crank
Fault code: 2F44 EWS preventing manipulation.
This is a common fault code flagged by BMW vehicles when the EWS (also known as the CAS module or immobilizer) no longer communicates with the DME.
Some of the most common causes, for this condition, is battery failure or ignition key failure.
Many times, a customer will bring a BMW into the shop or have it towed into the shop, and explain that "the car just won't start, suddenly". Upon further investigation, it is common for a technician to find poor battery condition or a failed ignition key.
In the case of poor (low) battery condition. A low voltage level has caused the immobilizer (CAS/ EWS) to lose its alignment with the DME.
In the case of a failed key, the immobilizer (CAS/EWS) cannot "see" the key in the ignition and therefore will not allow the vehicle to start. This is the "no crank" part of this fault.
So where do we start?
Using a factory level scanner, connect to the vehicle. After identifying the vehicle, proceed to the immobilizer module (CAS/EWS) and investigate if the key can be identified. If the key in the ignition slot cannot be identified and the key slot/ receiver is functioning correctly, then the key must be replaced. Typically, at this point, the first thing we want to do is ask the customer if another valid key is available. If so, let's try this first! If not available, a NEW key FROM THE DEALER, must be purchased.
NOTE: Aftermarket keys will not work i.e. E bay etc. The keys for these cars are VIN specific and need to be supplied by the dealer only!
A new key will work "right out of the box" from a dealer. Simply put it in the ignition, allow the vehicle to identify it (give it about ten seconds) and try a startup.
After replacing the key and regaining key identification the immobilizer (CAS/EWS) must be aligned with the DME.
Using a factory level scanner, perform the DME to CAS/EWS immobilizer alignment procedure. Clear fault code(s).
So, what about the battery?
All the above information is based on having strong battery voltage. In regards to BMW vehicles, 11.0 volts is NOT good voltage. These vehicles are designed to operate in the 12.4 to 13.0 (average) voltage area.
Before attempting to start the engine, a technician should perform a battery load test. When working with BMW vehicles, if the battery is marginal or too old (more than three years old) replace it.
NOTE: New batteries for later model BMWs (CIP vehicles from approx. 2004) will need to be registered. With a dealer level scanner, a tech can perform this function.
Note: As time passes BMW will change the way immobilizers are aligned. Typically, this happens when BMW changes manufacturers. If performing a standard CAS /DME alignment does not work, A later procedure is available. With late model (EWS 3 type onward) immobilizers, the tech must perform a three-step procedure. Using a dealer level scanner, carry out 1) CAS reset, 2)steering lock counter reset 3) reset the starter interlock.
May 04, 2014 | Cars & Trucks
The theft light on my ford taurus is on and stays on but the car runs fine there is just an issue: my turn lights randomly light up (both) and wont turn off , When this happens the dashboard does not...
Problem sounds like key or P.A.T.S. anti-theft module. Go to dealer who can plug car
into computer or a reputable shop that knows ford p.a.t.s system for
estimate. You can try to check fuses, but they are really hard to
get at under the dash.
Mar 05, 2013 | 2001 Ford Taurus
Takes a long time after Turn Off Computer button is pressed
Thats normal for many! It would depend on the amount of Ram you have installled.and the number op programs you have in an open state on the right hand side bottom task bar.
Use MSCONFIG ( Via RUN) to remove some of these programs from running at startup.This should help to close down faster
Jul 29, 2009 | Computers & Internet
Could be just about anything, but given that I had the same symptoms that turned out to the fuel pump, I would check that if you haven't already. Mine would run fine for a while, particularly when it was cold, and tested fine at the shop, but after a while under load, it turned out the pressure would suddenly drop to about 15 pounds. A real pain to diagnose, since when it was in the shop it wasn't under load, so it tested OK.
Jan 28, 2009 | 1987 Chevrolet Corvette
7.5 amp fuse blows, car will not start.
hello , if when you replace the fuse the vehicle starts and this fuse is for the ews check for a oil level sensor shorted or the wires going to it defective, this is wired in the same loom as the ews and the short will cause the fuse to go and the ews will not have power /when it rains the water will aid to the problem
Oct 29, 2008 | 1997 BMW 328
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
