Question about Oster OGB61101 Microwave Oven
Oster microwave no power
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Check your fuses
Posted on Mar 31, 2014
My Oster microwave. Last night we had a pretty big storm, this mourning I tried to use my microwave, No power. I switch plug in outlet ...Nothing happens. How do I get the power back on ?
Depends on what blew, if ti is a power surge is will blow out the low voltage transformer on the main board before it will blow the fuse in the unit, so Probably will need new main board. Problem will be finding someone who carries parts for Oster Microwvaes.
Oct 05, 2017 | Oster Microwave Ovens
Microwave oster
could possibly a blown internal fuse .
Jan 23, 2018 | Oster OGH6901 0.9 Cubic Feet Digital...
My oster OGB8901 microwave is having power situations it sometimes the power works and sometimes not i can hit the top and the power will come on than in the middle of cooking something it (the power)...
Hi, Could be a timer issue. Don't hit it anymore you will do more damage to it or even get a shock. Take it to a repairman or someone that has worked on one. Good luck.
Mar 17, 2014 | Oster OGB8901 Microwave Oven
Oster om1201Eovg will not shut off
The microwave should have lasted at least 5 years, Oster has demonstrated that profit comes first and the customer last.
May 29, 2012 | Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
Microwave has no power
Hello, welcome to Fixya!
The unit not powering on is an indication that it has a power fault.
First, remove the microwave's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the microwave, it goes straight into the power supply board which then circulates the current into the unit. So if the microwave doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This microwave must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the microwave turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store within our vicinity.You might also find visible bad component without testing with a meter. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Jan 25, 2012 | Kenmore Microwave Ovens
No power to microwave?
Regards.
s
Jan 06, 2012 | Whirlpool MH3184XP Microwave Oven
Neff C57M 70S0 POWER FAILURE
Regards.
Jan 04, 2012 | Neff H7871N2GB Convection / Microwave Oven
EMERSON MWG9115SL-D WILL NOT POWER UP
The unit not powering up is an indication that it has a power fault.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Regards.
Nov 22, 2011 | Microwave Ovens
Oster OGB61101 Microwave Oven Logo
102 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
