Question about Home
Not getting gas
I am trying put the carburetor on Moto 4 back together and need an illustrated parts break down of the carburetor. I didn't take it apart but have a rebuild kit for it and need to see how to reassemble it
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 97 Answers
Just take digital pictures as you dissemble it. Most carbs of a given type are basically all the same. Watch these carb videos for more info:
http://www.cmsnl.com/yamaha-yfm80t-moto-4-1987_model9323/partslist/A-10.html#results
Carburetor Cleaning Part I
http://youtu.be/w4vW4zh8g0Q
Carburetor Cleaning Part II
http://youtu.be/ig0qHhdxJFE
Carburetor Cleaning Part III
http://youtu.be/EjCmiZ5xoeU
Posted on May 16, 2014
How to Clean an Outboard Carburetor?
didnt specify unit --generic answer --best way is to buy a rebuild kit [should have instructions]--carb cleaner --disconnect carb --and tear down the carb becareful their are small parts inside using cleaner cleal all parts and housing --in the rebuild kit should be instructions on putting it back together
15 minute Carburetor Cleaning Rebuild Yamaha 20HP outboard 4 stroke How to Clean an Outboard Carburetor Outboard Motor Carburetor Cleaning
Oct 20, 2016 | Boating
MY RYOBI GAS BLOWER AND VAC IS HARD TO START. IT IS NEVER BEEN USED SINCE I PURCHASED IT FROM HOME DEPOT. I HAVE ONLY BEEN ABLE TO GET IT STARTED TWICE AS A TEST START BEFORE USING IT. WHATS THE PRO
Without seeing in my shop it will hard to tell exactly what is going on. I have ran into a couple starting problems with Ryobi blowers. They carburetor were either being over choked or not enough choke. Both were Ruixing carburetors. Something you can try to find out if it is the carburetor into add a little fuel mix directly into cylinder through the spark plug hole.
Depending on how long you have had it, it may still be covered by the warranty and I would check into that if I was you.
Dec 09, 2014 | Ryobi 2 Cycle Blower/Vac 51984-R
Do the carbs on the 1983 vf400 come off one by one or all together and any tips i should know to get them off thanks josh....
The carburetor rack comes off as an assembly. All four at the same time. You need to take extra care with Honda v-4 carburetors, if you twist or flex the rack you can break the feeder connections between the carburetors. Often the tiny orings have broken or started leaking by now. A major problem with all Honda v-4's. If you take the rack out try not to separate the carburetors or you will have problems with the feeder pipes and o-rings (they will leak when you put them back together.)
Oct 23, 2010 | 1983 Honda VF 400 F
Engine is bogging down
Sounds like a fuel issue. Just enough gas getting there to start it, but not enough to keep it running. Start at thefuel line to the carburetor. Make sure fuel will come out at a sufficient stream. If it doesn't, work backwards towards the fuel tank, looking for clogged fuel lines and such. Clean whatever is suspect. If you get fuel all the way to the carburetor, you'll need to clean the carburetor. Careful disassembly is critical to getting it put back together correctly. Clean your parts with brake cleaner, not carburetor/choke cleaner, paying particular attention to orifices.
Best Regards, --WoobieDog--
Jul 10, 2009 | Garden
Corrossion in fuel tank . difficult starting.
For the corrosion in the fuel tank get a liquid tank liner. It lines the fuel tank walls then hardens to seal the tank from rust. Google “ kreem fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
For the hard starting, clean the carburetors. (unfamiliar with your bike, I assume it has carburetors and not fuel injection).
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetors. There should be a screw on the lower side or bottom of the CARB float bowls. Remove the drain screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carbs to fill with gas. Install new stock NGK spark plugs and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
FOR EACH CARB > Remove the float bowl and clean the entire CARB with a spray CARB cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the CARB. Remove the idle screw and the air screw on the outside throat of the
CARB and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
CARB back together, clean the air filter and install the CARB. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Jun 12, 2009 | 2000 Moto Guzzi Nevada 750 Club
Home Logo
126 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
