Everlasting loop when trying to calibrate the touchscreen. After the touchscreen stopped working I did a (soft-) reset and tried to recalibrate the screen (went there using the navigation buttons) because the touchscreen still didn't work. It asks me to click a target, but I just keep clicking the things (upper left, lower right) and nothing happens, I just switch back and forth. Any help would be appreciated...
Comments:
Jun 19, 2009
- FIXED (edited quote:)
You need to take the Palm z22 apart. Use your finger nail to pry off
the small cover that surrounds the UBS connecter. Then unscrew the two
screws you see. Now Stick your finernail into the middle side of the
Palm. Where the white tope meets the black back cover. Use a very small
screwdriver to go into the space you made with your fingernail, and pop
the plastic holders. You can see where the clips are by looking at the
side.Careful not to break anything.
Now your palm is open. The touch screen connector needs to be removed
and put back in. Remove the plastic retainer (=black plastic cover) , pull out the mulit cord
ribbon (=small flat bronze cord, the smallest of the two) by levering the little clip, put it back in, put back the retainer.
Next move the black plastic foam that is on top of the retainer clip. I
think when you close the case it squeezes the retainer in a bad way.
Put everything back together. If your scrared to try it send me your
palm with some stamps for return postage and I will try it for you.
Palm set up options are greyed out so I cannot access set up. My palm is not syncing. What should I...
(More)
Palm set up options are greyed out so I cannot access set up. My palm is not syncing. What should I do?
I have a palm z22 and no installation disk or charger. Can I charge from the computer cable and how...
(More)
I have a palm z22 and no installation disk or charger. Can I charge from the computer cable and how can I install it on my computer?
