Question about Casio FX350MS Scientific Calculator
How to get complex mode in 350 in mine oly comp mode is available?
Regarding complex mode
  • Casio Master
  • 8,046 Answers
Sorry, but you cannot. This calculator has three modes only: the general COMPutational mode, the Standard Deviation Mode and the REgression mode.
Posted on Mar 30, 2014
Fix the mode
Try a reset SHIFT 9 (CLR) and reset 3:All
Also if Mode:1: COMP gives Complex, maybe MODE:2:CMPLX will give you the usual COMP mode. (wires may be crossed). I have a calculator that has two keys inverted. I made a note of it and keep it taped inside the sliding cover.
Jan 02, 2014 | Casio FX991ES Scientific Calculator
HP Envy display stays dimmed after waking from sleep mode
Hi, i made several searches on google for you problem but did't get a right answer except this link. They provide support for HP Envy Laptop. Why not you try to call them on +1 (844) 355-5111 toll-free number.
Jul 20, 2017 | HP Computers & Internet
How can I reset my Casio FX-115 ES calculator to its default settings
There must be an error in what you report. You pressed MODE then 4: Base-N and now your calculator is in base-N calculation mode (the DEC, Hex, BIN, OCT) numeration keys are active.
To do statistics you must put the calculator in STATS mode.
Press MODE: You have 6 computational modes to choose from
1: COMP, the general computational mode
2:CMPLX, for calculation s with complex numbers,
3: STAT for statistics,
4: Base-N, binary, octal, decimal, and hexadecimal numeration
5: Equation, solving mode, etc..
For statistics, choose 3:STAT
Apr 24, 2012 | Casio FX-115ES Scientific Calculator
My fx_115ES casio is displaying Dec and I don't know why!
You're in BASE-N mode for integer arithmetic. Press MODE 1 to get to COMP mode for real arithmetic or MODE 2 for CMPLX mode for complex arithmetic.
Apr 04, 2011 | Casio FX-115ES Scientific Calculator
How to get from dec. to binary
If you're already in decimal mode, press SHIFT BIN to switch to binary mode.
To convert a number from decimal to binary, press MODE 4 to switch to BASE-N mode. You'll find yourself in decimal mode. Enter the number to convert, press =, then press SHIFT [BIN] (the log key) and see the number in binary. To convert another number, press SHIFT [DEC] to return to decimal, enter the number, press =, then press SHIFT [BIN]. An analogous process works for hexadecimal and octal as well.
To return to "normal" use, press MODE 1 for COMP mode or MODE 2 for complex mode.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
How to get the imaginary numbers on the 115es casio calculator? It is in purple and i cant get it with shift.
You need to be in complex mode before you can do any calculations involving complex numbers. Press MODE 2 to switch to CMPLX mode. When you're done, press MODE 1 to switch back to COMP mode. (Yes, the names are confusing. I didn't pick them.)
Dec 14, 2010 | Casio FX-115ES Scientific Calculator
A/c compressor lock up and leaking oil from the rear of the a/c comp. not cooling well unless driving at 1500-200 rpms.
If compressor is leaking,so is the refrigerant. A new , used,or rebuilt would be your oly option at this stage. Sorry.
May 25, 2010 | 2004 GMC Yukon
How to get mod on it
If you are thinkink of the modulo function, usually shortened to mod(, I am sorry to say it but that function does not exist on the calculator.
However, there is MODE button that one uses to set the operation mode of the calculator.
You have three principal mode setting
COMP: the general computational mode
SD: a statistics mode to calculate Standard Deviations
REG: to perform REGression analyses on statitical data.
Once you have chosen the preferred calculator mode (COMP, SD, or REG) other choices (dependent on the main calculator mode) will be available.
May 03, 2010 | Casio fx-300ES Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Noisy
I had the same problem with mine. The only solution we could come up with was to place a small towel/washrag underneath it, and wedge it into something if you can. This solved our problem.
Sep 29, 2007 | Wave Industries OLY-OL3000 Globe Phone
Casio FX350MS Scientific Calculator Logo
108 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
