Question about Skytech Home Security
How do we re learn the code on a receiver (batteries were changed however we still have to light manually)
We have changed batteries on remote control and on two receivers. The remote still will not start or turn off fire place. We have to do this manually. We were told that we need to re-learn the code on the receiver. How do we do this?
5 Suggested Answers
  • 188 Answers
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Posted on Jul 23, 2009
  • 4736 Answers
SOURCE: receiver was beeping all the
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Posted on Feb 03, 2011
  • 4736 Answers
SOURCE: I have a Sears Craftsman
Depending on how old your Remote Control Smart 3 Function remote is determines on how to access the battery compartment. It will either have a small screw which needs to be loosened or if it doesn't have that, it will pop open when a very small, thin, flat blade screw driver is inserted in the side seam of the plastic housing. It's going to be tight, so be gentle with it. Once you access the wafer battery, note which side is up (+ or -). That's the way you want to install the new battery.
Hope this helps you out.
Posted on Feb 14, 2011
  • 59 Answers
SOURCE: Hi - I need the manual to my garage door, so I can
Chamberlain garage door opener and remote manuals
Posted on Mar 16, 2011
How do I change the frequency of a garage door opener 139.53930ODM?
Hi... You have to "erase all codes" (you can read that section of the manual and teach the opener to use the remote using a new code. You can get the manual at the Craftsman site, page 35. Essentially you do this: access the reset button n the back right of the motor, press and hold the 'learn' for 6 seconds or more,until the learn light goes off. TO reprogram it, press the learn button until the light goes on, then within 30 seconds, press and hold the desired button of the remote. Voila!
Dec 26, 2014 | Chamberlain Liftmaster 355LM 315MHz Garage...
How can I get my onkyo remote control (RC-693M) to control my Sony LCD tv?
Manual says: 1. While holding down the REMOTE MODE button for the mode in which you want to use the command, press the [ON] button. *** Hold both buttons down for 3-4 seconds *** 2. Press the button you want to learn the new command 3. Point the remote controllers at each other, about 2-6 inches apart, and then press and hold the button whose command you want to learn until the Remote indicator flashes. *** Hold them level with each other, 2-3 inches apart, and don't move them at ALL while you press the button on the old remote *** 4. To learn more commands, repeat steps 2 and 3. Press any REMOTE MODE button when you've finished. *** If the command was learned correctly, the remote indicator will flash *SLOWLY* twice - about a 1 second blink, and the red light will remain on. If the command was NOT learned correctly, it will blink twice *QUICKLY* - about .5 seconds, and the red light will go off. *** If the red light stays on, you're golden - keep going until you get to a button that flashes red quick and the light goes off. Some of the buttons I programmed took 6-7 tries in exactly the same position to learn.
Oct 09, 2012 | Onkyo TX-SR705 Receiver
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a Skytech 1001 TH-A thermo remote. Everything was hooked up correctly, but the remote continues not to work. When I turn the remote off, the fireplace comes on and vice versa.
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Jan 02, 2011 | Skytech 1001-A Fireplace Remote Control...
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
My neighbors garage door opener opens my garage door. How do I fix this.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jul 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you reset the controls on an remote control for my onkyo tx-ds575
See the manual you can download on this site on page 39
1. Open the battery cover and remove the batteries.
2. While pressing and holding down the ON button and the
STNBY button, insert the batteries in the correct direction.
After inserting the batteries, release the buttons. The SEND/
LEARN indicator flashes slowly.
3. Press the ENT button.
The SEND/LEARN indicator lights up for about ten seconds,
then turns off. All programmed codes are erased and the button
memories return to the factory presets
Jun 30, 2010 | Onkyo TX-DS575 Receiver
Ocasionally my garage door will open by it's self, how do I stop this problem. It's a Sears Craftsman model #139.535355SRT1, 1/2hp .
Somebody in the neighborhood probably has a remote that is on the same code as yours. Try changing your codes first, to see if problem stops. Consult the owner's manual for code instructions.
A transmitter nearby can also create noise on the remote push button switch as well, and perhaps trigger the door to cycle. You should be able to disconnect the pushbutton switch at the opener, and use remotes until satisfied that problem has been corrected. If this is the case, talk to Tech Support line (again, in manual) about reducing noise / interference susceptibility.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lost the Hughes manual. I need the code settings for the remote
Here are two links for the manual you are in need of:
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
http://www.solidsignal.com/manuals/HRMC-11_HRMC-12_Owners_Manual.pdf
Either of theses should get you to the correct manual and should have the code you need.
Feb 27, 2009 | Hughes HRMC11 Remote Control
Home Security Logo
57 people viewed this question
Top Skytech Home Security Experts
Lawrence Oravetz
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
