Question about Shop Fox W1713 16-inch Variable Speed Scroll Saw
Installing new motor
Replace bad motor with new motor. trouble removing old motor
Replace electric window motor
Not much to your question, or what you need to know
You have to figure out how to remove the inner door panel
Then figure out how to remove the window regulator,if you find
it broken
Then if the motor or regulator needs to be replaced-- after testing
the motor,you have to remove the motor, in some cases & put
on the new regulator, or just install a new motor to old regulator
This is if those two items are the problem,could be a bad switch
Jul 16, 2013 | 1996 Lincoln Continental
Tip
The motor is running, but the drum isn't spinning.problem with dryer.
Nine times out of ten it's a broken belt, but there are other factors that can cause this problem. <br /> <ul> <li>Broken belt -- Replace with an identical belt. Line up the new belt with the markings on the drum from the old one. Wind it around both the motor pulley and the idler pulley.</li> <li> Roller could be bad -- Underneath the tumbler is a roller that the tumbler sits on. It may have become too worn to work properly and may need replacing. Replacing it is simple - just remove the tumbler to gain access and then remove the retaining clip on the roller and slide it off. Reverse the process to install a new one.</li> <li> Motor or idler pulley could be bad -- Check the pulleys to ensure they're still in working order.</li></ul>
on Dec 24, 2010 | Dryers
1999 Cadillac deville had a new alternator installed and a new battery replaced. when car sits down, car will not crank. car has to be jumped off.
REPLACE BATTERY CABLES.SOUND LIKE POOR GROUND AT BATTERY GROUND CABLE.IF BATTERY CABLES OLD AS VECHICLE REPLACE THEM.TURN OFF RADIO FIRST BEFORE REMOVING BATTERY CABLES.IF BATTERY CABLES OKAY.THE STARTER MOTOR COULD BE GOING BAD.
Apr 28, 2011 | 1999 Cadillac DeVille
The heater fan needs to be replaced. I think the bearing is bad cause it makes a vibration noise when its on HI. Just need to know the location of the fan and is it easy to replace.
You should be able to see it under the hood on the passenger side of the car. If you have trouble identifying it...just follow the noise. To replace it all you have to do is disconnect the electrical connector. remove the screws from the motor flange, and remove the motor and fan assembly as an assembly. Your new blower motor may or may not come with a new fan. You may have to transfer the fan from one motor to the other. If it is vibrating really bad, the fan itself may be damaged and you might have to replace it also. There are blower assemblies for some vehicles that come with a new fan already installed - check with your local parts supplier.
Mar 08, 2011 | 1986 Buick LeSabre
I believe I need to replace the motor. My cooler started making a loud noise and then just shut off and now it won't turn on at all. I'm new to this and have to do it myself but I'm having trouble finding...
Hi!!
DISCONNECT POWER TO UNIT BEFORE SERVICING.
There is not much to it, to access the belt/motor, remove side panels, loosen motor base bolts and push motor inwards to relieve pressure on belt. (you have to do this even if the belt broke off in order to install the new one), remove old belt and install new one. Slide/Pull back to tense belt. Proper tension is achieved when push belt with your finger between pulleys and the deflection is about 1/2"
Good Luck!!! Don't forget to rate this post!!!
Aug 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Water runs out of the bottom of the washer as rinse water runs in. Washer if top loading Whilrpool. Model #WTW5840SWO
Check the pump assembly ( this is a common pump ) first for a leaking problem, check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tips: This pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
May 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint fan oven motor removal - Fixed!
no problem glad to help you
Mar 31, 2008 | Ovens
Eureka the boss vacuum cleaner brush won't turn
Take the top cover off, remove the torx screws on each side of the motor housing, remove the screw on the back holding the hose, then you just have to compare the 2 before putting on the new one. Can't tell for sure without a model number to get you a picture. What isn't on the new base, take off the old base and put it on the new one.
Jan 26, 2008 | Vacuums
Shop Fox W1713 16-inch Variable Speed Scroll Saw Logo
32 people viewed this question
Top Shop Fox Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Shop Fox Saw Expert? Answer questions, earn points and help others
