Question about Vehicle Parts & Accessories
My husband tried to change out the fuse for the cig. lighter in a 2006 Mazda 3. It blew... Now the lights and everything works but the car will not start. What can I do????
It sounds like it is trying to turn over but it cann't.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 159 Answers
Check the wirring and the starter relay
Posted on May 11, 2014
2 Suggested Answers
bigjohns17
SOURCE: my total closure has stopped doing the windows
hi did u ever fix this as i have the same problem
Posted on Jul 14, 2012
Horn and cig lighter won't work
disconnect the negative terminal on your battery first.
Jul 02, 2013 | Saturn SC2 Cars & Trucks
Lighter fuse
Yes.
The OBD connector for the scanner is powered by the same circuit as the cig lighter. If the fuse is blown, the testing facility can not access the computer on the car.
May 29, 2013 | Chevrolet HHR Cars & Trucks
Blew a 25 amp fuse for the cigarette lighter, replaced it with a new one but still not getting any power from the cig lighter, is there another fuse hidden somewhere??
No power from the cig lighter if you have a voltmeter youll have to test it for power at its harness behing the cig lighter, just to let you know that cig lighter also wears out and a replacement may be it the fix for you,also there is only one fuse for it
Jun 04, 2011 | 2006 Pontiac Montana SV6
Power windows and signal lights not working after i put in a power converter into one of the cig lighters
Most likely is that the converter was able to pull too much power and blew a fuse. I would check your fuses, in this case also check the main fuses under the hood as it seems like it may be more than one system.
Nov 30, 2009 | 2001 Mazda Tribute
I need to know which fuse is for the auxillary (cig lighter)
cig lighter circuit is usually a 10 amp fuse, which is red. look at the red ones first.
Jul 20, 2009 | 1993 Mazda Protege
Cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
May 06, 2009 | 2003 Toyota Corolla
My cigarrete lighter doesnt work, so i think i blew a fuse, but i dont have the fuse cover so i dont know which fuse it is i need to change so please just get me the fuse i ened to change caus ei need that...
all you need to do is buy a cheep test light in the 5-10 range. ground the test light and touch the metal in the fuse you do not need to take the fuse out. check both sides of the fuse you will see 2 metal pices on the back of the fuse were it tells you how many amps the fuse is. that is what you touch with the test light. the light should light up if not the fuses are bad. if the fuse is good take the test light and ground it again you can clip it to the side of the cig lighter socket. and put the test light prob into the cig lighter socket becarefull not to touch the sides of the socket and just touch dead center bottom and if the test light does not light up you know your Cig socket has burnt out
Apr 20, 2009 | Nissan Maxima Cars & Trucks
Cigarette lighter and radio not working on 2002 Honda coupe
They probably share the same fuse. Sounds like cig lighter coil is shorted and "fiddling around" blew the fuse. Replace the fuse and try a different lighter coil.
Mar 19, 2009 | 2002 Honda Accord
No power to cigarette lighters
Two years later and you solved my dead cigarette lighter. manual says fuse 35--but it did not say to check 38 on the left fuse box. Thanks--blown fuse and everything works. Thanks
Dec 20, 2008 | 2007 Volkswagen Passat Sedan
Ford Windstar Cigarette lighter
cig lighter you can change it easy you have to hold the inner piece with our hand and the piece inside the ashtray you have to turn it conter clock wize with our finger or pliers our dash light if all light were working good and all of a sudden it stop working check the fuses
THANKS FOR USING FIXYA
PIERRE
Feb 21, 2008 | MTX Ford Explorer/Mercury...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
