Question about Samsung ML-3560 Laser Printer
Samsung ml-3560 will not initialize
Printer restarts continually but will not initialize
    Habit-Forming:
    New Friend:
  • Samsung Expert
  • 150 Answers
Hi,please cheque printer papper jam & please take the jamed papper after printer is turn on to contiue see the error please replace the high voltage power supply
Posted on May 06, 2014
Nubar
  • 51 Answers
SOURCE: Engine low heat problem
This problem is probably caused by a problem with the fuser unit.
It should be replaced.
Posted on Dec 12, 2008
  • 220 Answers
SOURCE: samsung ml-1710 printer continues to jam paper;
pickup roller and seperaion pad req changing
Posted on Jun 22, 2009
SOURCE: ML-2570 Samsung printer having problem orange LED is blinking
restart than on
Posted on Jul 10, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Samsung ML-2152W won't initialize
I am working on one of these right now for a customer. It is doing nearly the same thing. I am 99% sure it has bad capacitors in the power supply. I have removed the power supply board and found swelled and leaking caps. I will get them replaced to verify, but I am positive that is the solution. Your printer will need either a new/repaired power supply or have your existing power supply board repaired.
Good Luck
Posted on Nov 26, 2009
SOURCE: Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
Posted on Jan 12, 2010
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
I can't install Samsung ML-1510 on Window 7. Could you help me solve this problem? Thanks.
Hey,
You just need the Windows 7 compatible driver for your ML-1510. I had the same issue with my Samsung ML-3560. Here is your link:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Samsung%20ML-1510%20Laser%20Printer&v=Samsung&uid=ML-1510&pf=0&pi=0&s=samsung%20ml-1510&os=64-bit
Choose the 32-bit or 64-bit depending on what you are running,
Good luck!!
EJ Kudelka
Nov 23, 2010 | Samsung Office Equipment & Supplies
Low heat error for ML-3560
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Sep 06, 2010 | Samsung ML-3560 Laser Printer
How to make samsung ml3560 print on both sides of a page?
download the manual from (http://www.retrevo.com/support/Samsung-ML-3560-Printers-manual/id/260ci255/t/2/). it has the complete user guide on how to manage your printer.
May 10, 2010 | Samsung ML-3560 Laser Printer
There is not any paper jam in it but message will apear
Try to reset the printer by restoring all setting to default.
If not working, then I need your HP model to help further.
Apr 25, 2010 | Samsung ML-3560 Laser Printer
Good Luck
Nov 26, 2009 | Samsung ML 2152W Laser Printer
Dec 12, 2008 | Samsung ML-3560 Laser Printer
Samsung ML-3560 Laser Printer Logo
105 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
