Question about CAD Microphones GXL2200 Professional Microphone
Gxl 2200 how to connect the microphones into a laptop
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 71 Answers
The easiest way to do it properly would be to use a small mixer, with an adapter cable from the outputs (usually 1/4") to the line-in of the laptop (usually 3.5mm stereo).
Posted on Mar 29, 2014
  • 3 more comments
  • Julie
    Julie Mar 29, 2014
    Oh so I have to buy a adapter cable because right now I just have the microphone
  • John Bonnell Mic Mods
    John Bonnell Mic Mods Mar 29, 2014
    You will need several things.
    A phantom power source, such as a mixer or preamp. A mic cable between the mixer/preamp and mic (XLR). An appropriate cable between the mixer/preamp and the computer. There are also USB adaptors available, but I strongly recommend against that route.
    A mobile recording interface is also a good choice, in place of the mixer or preamp.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
But John is forgetting one VERY important thing .... Your laptop does not supply the 48 volts 'phantom power' that the microphone needs to work. You have two options: 1) buy a "Phantom Power Supply" from someplace such as Amazon.com and get an appropriate 'XLR female to mini-phone plug adapter' to plug into your computer .... or 2) Buy a USB Preamp that plugs into your laptop and the preamp will supply the 48 volts for the microphone. I use an M-Audio preamp for mine. There are lots of different models of preamps to choose from. Just make sure the description says it is able to supply 'phantom power'.
Once you have the mic plugged into the preamp, and the preamp plugged into a USB port on your computer, then you need to startup your favorite recoding program (I use Sound Studio on my Apple Macintosh) and open the Preferences, or the Audio Control Panel, and select the USB preamp as your sound source.
In other words ... that microphone cannot be plugged directly into your laptop through the factory supplied jack and have it work. It MUST have the 48 volts 'phantom power' to operate.
Posted on Jun 02, 2016
My gxl 2200 condenser mike is not working for my mix craft 6
The usual procedure when a mic is not working - check that the phantom power (+48V) is working, then try another cable.
If the mic is out of warranty and you're low on bucks, you might have to fix it. Unscrew the base, carefully holding the body sleeve up against the screen. Then carefully slide off the body to expose the PC boards. Check the boards and wires for cracked copper film and bad solder joints. Two tiny Philips screws will allow you to remove the REAR board for full inspection of both. If all is good physically, start checking components with a multimeter. (if you don't know how, StartPage it.) The circuit is similar to the one below, EXCEPT there is a low cut switch on the CAD 2200. If you find a bad component, most of them are pretty cheap to replace.
Feb 13, 2013 | CAD Microphones GXL2200 Professional...
Is there an internal microphone and if so where is it located trying to record myself i have a compaq presario 2200
Hi, the HP Compaq Presario 2200 PC has no built in or internal microphone. You will have to purchase an external one to record audio. The microphone jack, when viewing the laptop from the front, is located on the left side.
There are small round holes which are jack ports. From the front to the back, the microphone port to plug in a microphone is the second hole back. Here is a manual in case you need more help with your laptop: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | HP Compaq Presario 2200 Notebook
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
Does the Compaq Pressario 2200 notebook have a built-in microphone?
no built-in microphone of your laptop but you can use microphone by plugging it to microphone jack
Oct 12, 2009 | HP Compaq Presario 2200 Notebook
Microphone muted on compaq laptop presario 2200
first u plug in micro phone then u displayed the setting of microphone and then turn off mute
Oct 01, 2009 | HP Compaq Presario 2200 Notebook
Hp Presario Microphone.
This laptop doesn't have an internal microphone, according to page 6-2 of the manual, which you can get to by clicking here.
Page 5-3 illustrates where to connect an external mic, it's the input with a pink ring around it.
Apr 26, 2009 | HP Compaq Presario 2200 Notebook
I bought a GXL2200 and i cant hear my vocals.
The GXL 2200 is a condensor microphone. It needs Phantom power to operate, and get the correct levels for recording. Your lexicon interface should have a button/switch that says +48V phantom power, or something similar. This needs to be enabled before the GXL 2200 will work.
Mar 07, 2009 | CAD Microphones GXL2200 Professional...
Inspiron 2200 what headset with microphone?
TAKE YOUR OLD PEAR WITH YOU AND COMPAIR THEM
MAKE SURE THE PLUG IN PARTS LOOK THE SAME OR CLOSE TO THE SAME OR IT MAY NOT WORK
SAME LINKTH
CANDYMANGANDY
Jan 28, 2009 | Dell Inspiron 2200 Notebook
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Dell Inspiron 2200 microphone scenario
Any standard desktop microphone or headset with microphone will perfectly work. It requires simple crystal microphone which starts from few dollars. You can get from any IT store
Good Luck
Jan 18, 2008 | Dell Inspiron 2200 Notebook
CAD Microphones GXL2200 Professional Microphone Logo
231 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Miguel Luiz Martins
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
