Question about Poulan PP3516
Saw quits after cutting wood for about 5 minutes
I can cut wood for 5 or 6 minutes then the saw quits. It will start again after it sits for about 45 minutes and I can cut wood for another 5 minutes. This happens over and over. I put new gas and a new spark plug in but it made no difference.
Are you sure you have the correct amount of 2-stroke oil mixed in the gas? It sounds like it is overheating. Also check the engine to make sure the fins aren't clogged with wood shavings.
Posted on Apr 03, 2014
  • 14 Answers
SOURCE: Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
  • 42 Answers
SOURCE: new Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Posted on Mar 08, 2009
  • 23 Answers
SOURCE: 4 y/o oulan chain saw hard to start and quit running, no spark.
TRY RUNNING AT HALF OR FULL WHEN IT DOES POSSLBY BAD GAS/MIX IF YOU CHANGED THAT ALREADY CARB PROBALY NEED TO BE CLEAN
Posted on May 17, 2009
Fog Horn
  • 17 Answers
SOURCE: Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
Not used in 10 years. Was there gas left in the tank? If so the carb is likely gummed up and may need to be taken apart and soaked in "Gunk" solvent and a new kit installed.
Posted on May 26, 2009
SOURCE: my Poulan 3500 chain saw will not start
3500 poulan runs and secand stop
Posted on Oct 22, 2010
What are some tips to cut tree limbs by a pole saw?
safety helmet
safety glasses
cut smaller branches first
cut small lengths
have a friend as a look out for power wires and other obstructions that branches can fall on
never cut while on a ladder
use a trestle and not a step ladder
Apr 09, 2018 | Garden
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
Oct 07, 2014 | Makita 10" Dual Bevel Sliding Compound...
My saw just cuts off after running it a couple minutes then it wont start back until it sits a little while
My first thought is the vent for the fuel tank is partially obstructed causing a slight vacuum to build in the tank when running, as it sets after it quits running the vent allows air into the tank slowly until the pressure equalizes.
Sep 19, 2014 | Garden
Wen miter saw will not keep 45 degree angle
I found a wood working forum and I think that there is a discussion that may assist you with this issue: http://www.woodworking.com/forum/archive/index.php?t-4424.html
Feb 23, 2013 | Wen compound miter saw
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
Chainsaw starts off running strong gets hot and quits after 10
Remove the muffler and inspect the piston and rings. If there are any vertical lines or grooves in the piston or the rings, you must rebuild the top end of the saw. (including cylinder)
Apr 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Hitachi 18v recip saw just quits.....battery life or saw problem?
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
Dec 31, 2008 | Hitachi 18V Lithium Ion Cordless Hammer...
Poulan PP3516 Logo
115 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
