Question about 1973 - 1980 GMC Jimmy Truck Cab Support 898-200
Starts but won't stay running
Just replaced fuel pump and fuel filter was running fine but stopped going down road
    New Friend:
Its a relay in you fuse box under ther hood , theres two of them together , the one on the right would probable be the problem , you can look on youtube on how to jumper it so you can get to parts shop if need be , the two relays control the speed of your pump if one voes all is lost took me two days to figure out was just glad to before i decided to change out pump , if you jumper the termanals dont try and drive for long time good for point a to b
Posted on Mar 29, 2014
We have a 2002 Chevy Suburban and it cuts out while driving down the road, about 20-30 mins after starting the vehicle. We've cleaned the fuel filter. As soon as we crank it up it'll run for 20 mins than...
there is code that does not turn on the service engine soon. have code retrieve.And when the problems occured have fuel pressure check.You have to find out if the problem is electrical or fuel and air .Another way to find it is move engine harness while engine running if it stall could be short to ground or wire cut open
Aug 28, 2013 | 2002 Chevrolet Suburban
2000 Ford Taurus 3.0 24 valve OHDC Engine fuel problems. Bucking engine when running down highway especially below half a tank to quarter of a tank. Fuel pump and fuel filter replaced 2 months ago. Se
Have a repair shop go for a ride with you, as you
explain the issues
Then have them diagnose & resolve
Stay away from the Genies in a bottle, they only take
your money
If you don't understand the product & don't test a thing,
don't think a can of anything - will do anything
Mar 16, 2013 | 2000 Ford Taurus
2.2L gmc sonoma ideas fine at accel and runs rough and dies
Common problems
1. fuel filter clog and fuel pump stop working
2. Crankshaft sensor (spark is cut during high demand)
3. Air filter clog (not enough air during high rpm
hope it helps
Jan 30, 2018 | 1999 GMC Sonoma
97ford truck fuel filter or fuel pump problems
LOOKS LIKE BLOGGED FILTER,OR THE TANK BREATHER WON'T WORK.SIMPLE TEST REMOVE THE FILLER CAP AND DRIVE IT FOR FEW MILES AND FOLLOW IT.
Aug 29, 2012 | Cars & Trucks
My 1991 honda civic runs fine going down the road, when I shut it off it wont start is there more than one relay for the fuel pump.
Not that I know of.
Are you getting spark to the plugs when it won't start, and how long do you have to wait for it to start ?
Aug 13, 2012 | 1991 Honda Civic
Chevy Malibu 2003 cranks but won't start! I know
You might have a defective fuel tank pressure sensor!
May 05, 2012 | 2003 Chevrolet Malibu
When engine warms up and you are driving and you let up on gas pedal to come to a stop it quits. Try to start it won,t start squirt little gas in carb it will start but if you let up on gas pedal it quits...
Change the fuel filter.
You may have to also change the fuel pump (sounds like it is getting weak) , but the filter is the cheaper/first step in the process.
Oct 05, 2011 | 1993 Chevrolet S-10 Blazer
2004 Ford Explorer idles fine but under load the engine stalls
Well an easy way to see if it is the fuel pump is to when its doing its thing and wont run spay some starting fluid into intake to be sure its the fuel pump..If stays running you know the answer.If problem still persists I give you other scenarios to try to fix the problem...
Mar 29, 2009 | 2004 Ford Explorer
1973 - 1980 GMC Jimmy Truck Cab Support 898-200 Logo
85 people viewed this question
Top APN Auto Body Parts Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an APN Auto Body Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
