Question about KLH Audio Players & Recorders
How to set channels
Want to know how to set fm channels
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
FM channel set at 88.5, too noisy, need to change the channel to a quieter channel
Use the FM extender kit to improve the signal. You can change the channel by holding down the cassette icon to enter the menu, then going to FM options (I think it's under settings)
Jan 07, 2011 | Sirius Sportster 5 Satellite Radio...
What or how do I install my Skyfi2 in my car without a tape deck?
Do you have a newer one (red and yellow box) or an older one (bubble box or white box?). If it says 'direct connect' in a reddish box it has a really cruddy FM modulator, if it is an older model from the clear plastic bubble box or white box, it has a really, really strong FM transmitter in it (so strong, the FCC outlawed it) and you can use it to transmit to an empty FM channel (within 50 feet of your radio!) So my answer is, simply go to the 'MENU" and under "FM Frequency" select an empty channel in your area, like 107.3MHZ and then set your car radio to 107.3 FM and it will come thru. You can also adjust the "Audio Level" in the MENU to make it even louder. Should work real well, Just check at the very ends of the FM band for channels first and try to set it 2 channels away from an active channel, so if you have a station on 106.5, you want to be on 106.9 or higher, etc.. Okay?
Jun 14, 2010 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
How do i save radio channels in transcend mp650
Go to settings->FM reset->Yes
Now all your FM settings will be deleted.
Now just go to FM, automatically the radio channels will be saved.
Cheers...!
Mr.Maduraikaran.
Feb 13, 2010 | Transcend T.Sonic 650 MP3 Player
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
Only in certain areas and passing vehicals cause interferance
I'm assuming your using a RF unit (radio frequency). Whether this unit inserts in the antennea line or is simply broadcasting an FM signal via it's own antennea, it is still transmitting a low power FM signal. The idea here is to find an unused FM channel in your area, set your radio to that channel and program the Sony RF unit to use that channel. The signal the Sony RF unit is transmitting is low power due to FCC regulations and to minimize the possible interference you could cause to someone else's FM listening.
You are likely using an FM channel that is being overpowered by a real FM radio station. This is usually solveable if you only travel in your town by picking an empty FM channel. If you travel alot, the channel in your town that is empty may not be the case when you travel 50 miles away. That's just part of the problem inherent when using radio frequencies to get your music into your radio. You have to be willing to deal with it.
As far as passing vehicles, I'm going to assume that the vehicles that are interfering with your radio are doing the same thing you are doing, they are using FM radio frequencies to pump music into their radios and they are using an FM frequency close to or the same as the one you are using. Since having an unused channel on the FM band is pretty rare these days, if there is one, you can bet everyone is trying to use it for their own purposes since it is "quiet", until you come around!
Aug 07, 2009 | Sony CDX-454RF 10-Disc CD Changer
I lost the owners manual for my Innova - Trifecta Digital AM/FM Clock Radio with Built-In Apple® iPod® Dock Model: VR880SA | SKU: 8955222 and do not know how to reset the preset channels
I have the manual.
1. Press the FUNCTION button to select FM or AM mode
2. Press SKIP to select station.
3> Press and hold the Memory button to enter channel saving mode.
4. Press the Memory button to select desire preset channel #.
5. Press and hold the Memory button again to save into memory. If it has been previously set, the former station is replaced.
6. Repeat step 2 and 5 to store addtl. stations.
Any idea as to how to set the volume during alarm mode, it's too loud!!
Jun 04, 2009 | Audio Players & Recorders
How to set presets gpx rdt4004sp
You can store up to 10 channels. For channels 1-5:: Go to station you desire. Press MEM button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels. After you store to buttons 1,2,3,4,5 then: For channels 6-10: Go to station you desire. Press MEM button. Press +5 button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels.
May 31, 2009 | GPX RDT4004SP AM/FM Radio
Sony CDX-SW200 AM/FM/CD unit
I'm not completely certain about yours, but on most Sony decks you can get to a manual tuning mode by pressing and holding the seek buttons. In other words, if you press and release the tuning button, it will automatically jump to the next channel. If you press and hold the button for a second, it should beep and possibly start flashing an "M" on the screen. After that, it should stop scanning when you release the button, without jumping to the next station.
Aug 10, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
16 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
