Question about Ovens
Electrolux insight ekc6044k
Hi the fan in the oven part is not moving around.
  • 20 Answers
If light comes on and oven still heats then probably needs new fan motor. best to seek out an appliance engineer.
warmest regards
Richard the Repairman
Colchester Repairs in Essex
Posted on Mar 31, 2014
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
Electrolux Gas Oven EOG6330; Cooling fan still on several hours after oven turned off. Solution, please.
hi the change over stat is probably faulty one of the wires from the cooling fan will go directly to it. there are 3 wires on it. just replace it. 311 23 97-00/9 is the part no approx £18 +vat
Feb 09, 2011 | Electrolux EOG6330 Gas Single Oven
Hi i have an Electrolux eou63102x double oven but the fan has stoped working in the bottom oven can you tell me the most commen part that may need replacing
You really need to establish if the fan is getting a supply to it, if it is, and it is not working, then you need to fit a new fan motor.
If no power to it, then could be a faulty switch, or break in the wiring, a bad connection.or an internal fuse that has gone.
Hope this helps.
Dec 22, 2009 | Electrolux Ovens
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
