Question about Samsung Ps-wz410 Subwoofer For Ht-z410t Home Theater
Optic on home theatre
Circuit on board loose
    New Friend:
  • 153 Answers
Dry sold all ur power supply diode n capacitor mat b solved ur problem
Posted on Jun 02, 2014
Optic not working on home theatre
there r two hole in ur optic one is tr n other is rx u have seen in tr leser light mark it contineous glow or disconnect if it is continious change ur optic cable
Mar 29, 2014 | Samsung Ps-wz410 Subwoofer For Ht-z410t...
My 6270 backlight when it suppose to turn on sometmes it doesn't or sometimes comes on dim. If I tap the side it comes up bright. I am familiar with trouble shooting circuit boards to a component...
Sound like u have loose Fiber Optic cables connections cables somewhere,if u tap the side of it comes back brightter.Take the unit aparts and tries reconnected all the Fiber Optic cables tightly if it work.Tries it out the unit turn it on/off 5 or 6 the backlight go up good and bright.Take hot glue gun glue all the Fiber Optic cables connections together for good.
Aug 11, 2011 | Ademco 6270 Graphic Touchscreen Touch...
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
Connecting sony dvd home theatre with led tv
If your Dvd player has HDMI out, then use this to take the picture to the TV. If it only has scart, then use this. Use a fibre-optic TOSlink cable to connect the audio from the TV to the Home Theater. If the home theater doesn't have Optical in, then use red and black phono(rca) cable.
Jul 20, 2010 | Sony Televison & Video
MY 6300.2 TREADMILL IS SHOWING A E3 EROR ON THE DISPLAY WEN START THE MACHINE CYCLE
ERR 3 Troubleshooting Inspect the optic sensor and other components as follows. Optic Sensor 􀁺 Optic sensor wheel – Make sure that the optic sensor wheel rotates securely, without wobbling, between the black optic sensor nubs. Realign and tighten if necessary. If optic sensor wheel teeth are missing or bent, replace the optic sensor wheel. 􀁺 Optic sensor wires – Check wire connections from the optic sensor to the drive board. Check wire continuity . 􀁺 Optic sensor – Turn on unit power. Turn the motor flywheel with your hand. The optic sensor indicator (LED10 on the drive board) should flicker. See MOTOR.08. If it does not light, and all parts above are OK, replace the optic sensor. Other 􀁺 Motor – Does the motor sputter, sometimes running fast, sometimes slow? See MOTOR.04. If the motor tests good, replace the drive board. If the motor tests bad, replace it. 􀁺 Drive board – See above, and inspect for burnt, damaged, or loose components. 􀁺 Main program IC - Press down on the main program IC on the display to ensure a good connection. Replace the IC if necessary
Aug 20, 2009 | Sportsart 6300 Treadmill
The disc says loading then it says no disc. as if its not reading on a GE home theatre system
try cleaning the optic head using cleaning disc available in the market, if it will not work, then replace the optic head with same brand.
Jul 26, 2009 | GE Audio Players & Recorders
We have a samsung ht-z515 home theater system and a new samsung ln-t4669f hd tv and I'm trying to hook up the system so we can hear it through the speakers. We are on Verizon Fios and I bought a Fiber...
Make sure the TV is set to output audio to the digital optical port. Then make sure you have selected the proper output mode on the home theatre. Unplug the optical cable from the back of the home theatre and see if the red laser is on (don't shine it in your eyes! :))
Sep 03, 2008 | Televison & Video
Samsung Home Theatre "Protection Error"
i've had a similar problem where the fan stopped moving and the system gave the usual "protect" error. i think the IC's burned out on the amp board since the error was no longer there when i unplugged it. i ordered a new board off ebey for $25 shipped. make sure this is the problem by unplugging both the power and data cables from the amp circuit (the board with the big heatsink) and starting it. if it says starts normally then the problem is the amp circuit
Mar 15, 2008 | Samsung HT-WP38 System
Samsung Ps-wz410 Subwoofer For Ht-z410t Home Theater Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
