Question about Samsung Ps-wz410 Subwoofer For Ht-z410t Home Theater
Optic not working on home theatre
The optic connected to circuit board seems to be loose
    New Friend:
  • 153 Answers
There r two hole in ur optic one is tr n other is rx u have seen in tr leser light mark it contineous glow or disconnect if it is continious change ur optic cable
Posted on Jun 02, 2014
Optic on home theatre
dry sold all ur power supply diode n capacitor mat b solved ur problem
Mar 29, 2014 | Samsung Ps-wz410 Subwoofer For Ht-z410t...
Pro-Form 545s......pushing speed #1 starts at 1.6....#2 starts at 3.2 and so forth
1) The normal functions is gradual o.1mph and so on until you reach the maximun speed.
2) check the speed sensor
http://www.youtube.com/watch?v=23ZgWaVEQjA see this videos and test the speed sensor and change if is faulty.
If LED does not light, inspect:1. Optic sensor signal wires and theirconnections; Reinsert wire ends into connectors.2. Whether optic sensor wheel rotates in themiddle of the sensor; If not, reinstall the optic sensor wheel.3. Whether optic sensor wheel teeth are brokenor bent; if so, replace the optic sensor wheel.4. If LED2, the VCC circuit indicator, on thedrive board lights and there is no optic sensor signal output(LED does not light), andif optic sensor wires and connections are good, replace the optic sensor.
2a) The main motor you must test:
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
3) otherwise is o.k you must replace the display board.
Nov 13, 2011 | Exercise & Fitness
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
HI, i have a white screen on this tv. it,s out of warranty being about 3 years old , one day it suddenly went white completely . opened it up to replace the inverter board , but did not cure it . when i...
No.This tv problem it is not a grounding earth problems.It is a loose connections Fiber Optic cables pins connections contact problems on that board some where,on those Fiber Optic cables on that board those pins connections are not made tightly between them on that area on that board,where it is loose,some where u put pressure on it inwards.Why don't u take all the Fiber Optic cables aparts and take long noise plier bents all the connections pins a little bit.Than re connections all the Fiber Optic cables again on that area should solve this problems.
Sep 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
My 6270 backlight when it suppose to turn on sometmes it doesn't or sometimes comes on dim. If I tap the side it comes up bright. I am familiar with trouble shooting circuit boards to a component...
Sound like u have loose Fiber Optic cables connections cables somewhere,if u tap the side of it comes back brightter.Take the unit aparts and tries reconnected all the Fiber Optic cables tightly if it work.Tries it out the unit turn it on/off 5 or 6 the backlight go up good and bright.Take hot glue gun glue all the Fiber Optic cables connections together for good.
Aug 11, 2011 | Ademco 6270 Graphic Touchscreen Touch...
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
Connecting sony dvd home theatre with led tv
If your Dvd player has HDMI out, then use this to take the picture to the TV. If it only has scart, then use this. Use a fibre-optic TOSlink cable to connect the audio from the TV to the Home Theater. If the home theater doesn't have Optical in, then use red and black phono(rca) cable.
Jul 20, 2010 | Sony Televison & Video
MY 6300.2 TREADMILL IS SHOWING A E3 EROR ON THE DISPLAY WEN START THE MACHINE CYCLE
ERR 3 Troubleshooting Inspect the optic sensor and other components as follows. Optic Sensor 􀁺 Optic sensor wheel – Make sure that the optic sensor wheel rotates securely, without wobbling, between the black optic sensor nubs. Realign and tighten if necessary. If optic sensor wheel teeth are missing or bent, replace the optic sensor wheel. 􀁺 Optic sensor wires – Check wire connections from the optic sensor to the drive board. Check wire continuity . 􀁺 Optic sensor – Turn on unit power. Turn the motor flywheel with your hand. The optic sensor indicator (LED10 on the drive board) should flicker. See MOTOR.08. If it does not light, and all parts above are OK, replace the optic sensor. Other 􀁺 Motor – Does the motor sputter, sometimes running fast, sometimes slow? See MOTOR.04. If the motor tests good, replace the drive board. If the motor tests bad, replace it. 􀁺 Drive board – See above, and inspect for burnt, damaged, or loose components. 􀁺 Main program IC - Press down on the main program IC on the display to ensure a good connection. Replace the IC if necessary
Aug 20, 2009 | Sportsart 6300 Treadmill
The disc says loading then it says no disc. as if its not reading on a GE home theatre system
try cleaning the optic head using cleaning disc available in the market, if it will not work, then replace the optic head with same brand.
Jul 26, 2009 | GE Audio Players & Recorders
Samsung Ps-wz410 Subwoofer For Ht-z410t Home Theater Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
