Question about Vacuums
Power brush vibrates
Tristar A101 brush is very loose and rattles when spinning
  • fred riano
    fred riano Mar 31, 2014
    my tristar A101 brush in the head unit rattles like the bearings are going bad. It vibrates and it is very loud and when i flip it upside down i can move the brush up and down with my hand about a quarter of an inch.
    Genius:
  • Vacuums Master
  • 1,069 Answers
Remove the brush roll and check to see if there is a problem. You might need to replace the brush roll if the bushings are bad
Posted on Apr 03, 2014
2 Suggested Answers
  • 10 Answers
SOURCE: Vibrates very loudly when brush starts spinning
take out screws on bottom and see if tension bar can be tightened, make sure the right belt is in there, also if belt looks worn or gouged replace with a new belt
Posted on Apr 23, 2009
How do I access the motor and replace the brushes on compact tristar vacuum cleaner?
I need the actual model number for that vacuum and then I can give you the correct/specific instructions.
Feb 03, 2015 | Tristar Vacuums
Tristar vacuum
The main motor has a bad carbon brush. It is fixable.
Sep 04, 2014 | Vacuums
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
Vacuum works, but makes an irritating rattling noise whenever I use it. Both speeds. There is not debris in the blade that I can see when I remove the handle and turn the brush while looking into motor...
There are moving parts that are likely the culprit. Start by examining the brush roll and make sure it is not loose or to see if the brush roll is not being held tightly in place. If it is loose it will rattle around.
Nov 03, 2013 | Oreck XL21 Bagged Upright Vacuum
I transported my newly given to me by my dad tristar from Fl to LA and I can't get the reset button to start the power. The vacuum comes on, but the rug attachment is not spinning I can't get
If the rug attachment is not spinning, it is likely the drive belt has come off. Also, the entire intake area probably needs to be cleaned.
If the vacuum cleaner starts, the reset button has nothing to do with why the attachment doesn't spin.
Sep 12, 2012 | Tristar Vacuums
How to get to belt on motorized FLoor cleaner? Has many odd shaped screws.IT is a TriStar EXL and stopped working so I believe it is the belt, but cannot get screws to operate even with a star screwdriver.
Thewre should be an easier way to access belt. Check under power head again, I cant see how there would a problem. Was you get in it the belt is easy to install. Put belt on motor shaft first, then roll it on the brush end. Chris
Feb 06, 2011 | Tristar Vacuums
Power's off when the canister is removed or locked in upright
you have a clog someware. you should invest in a tristar cleaner. cheep vacs dont have near enough power to get much more than the stuff ontop. i am a tristar authorized distributer,you can call me just to talk 866-635-9254 or go to tristarclean.com call me3 when you are ready to buy a tristar. John
Oct 19, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
Apr 23, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
