Question about Motorola Mobility att tl7610 dect 6.0 cordless headset
The mic is not sending a good signal
When using the head set, either the person being called can not hear us, but we can hear them, or vise versa while adjusting the lifter audio adjust
I have a htc t mobile 4g mobile but the problem is all the time head phone symbol appear on the screen and due to it i cannot hear the voice of the person who is calling to me and who i am calling...
Dear , Actually your problem is the audio jack of the phone ,so, either you open your phone (but be very careful) from pcb side(backside) & using twiser adjust the strips or goto a shop & replace the audio jack.
Dec 07, 2012 | HTC MY TOUCH HD 4G UNLOCKED QUAD BAND GSM...
Are the liftes adjustable on a 1992 ford expolrer
No,
You should have hydraulic lifters. They pretty much "self adjust". If work was done and the heads were removed or anything like that then there is a procedure for setting the pre load.
Is that a 4.0L? I seem to recall hearing about a lifter type tick. If this is your issue, what I have heard was they have bad pushrods. They mushroom and cause a ticking sound. If this is the case the pushrods and rockers should be replaced.
Oct 20, 2011 | 1992 Ford Explorer
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
When I call or receive a call they could not hear my voice. after unmute sometime it get rectified and sometimes not
problem with you phone software or your mic. try using with a head set and send the result.are helpful or not ?
Apr 28, 2011 | Nokia C3 Cell Phone
Does my 2005 chevy cavalier have adjustable hydrolic lifters
Hi, your engine has hydraulic lifters, but they are not adjustable. If you hear ticking there, a lifter has likely failed and needs to be replaced. please let me know if you have more questions, and thanks for using FixYa.
Mar 26, 2011 | Chevrolet Cavalier Cars & Trucks
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
Mar 13, 2011 | RIM BlackBerry Bold 9700 Smartphone
The person i am calling can not hear me
This is usually due to two reasons.
The first reason could be that your mic is set to the mute position so whatever you are saying is not getting into the mic. So therefore, the person at the other end cannot hear what you are saying since the mic is not transmitting whatever you are saying.
Secondly, the mic of your phone could have developed a fault or is broken. As a result, it cannot transmit whatever you are saying too. A very good way to know what is exactly wrong is to try and record a message or any tone on your phone. If you can hear the playback then there is no fault with your mic, but if you cannot hear the playback, then you have to change your mic.
The only way you can replace it is to send it to a repairer and have him fix it for you.
Hope this was helpful? Please comment for more information.
Jan 28, 2011 | Cell Phones
When I place a call to someone & they answer,I can haer them just fine but when I speak, they cannot hear me.What might the issue be with my headset? Motorola710
The fault is possible in the headset and you will need to check on the mic section. Check on the mic inlet for any block due to dirt accumulating , thereby blocking the passage of sound. Use a good soft fibre for cleaning and clearing the passage. If this wont help you will need to open the head set and ceck on the mic. Use a signal test on the mic to get a response on the answering phone. If so the mic is the main culprit. replace and proceed, However if the fault stays still, it could be the failure of the mic amp, try to solder this area and test. Hope this works for you. Good day
Jul 26, 2010 | Motorola Mobility H710 Bluetooth Headset
How to set timing and distributor in 1987 4.3 mercruiser(chevy)
If the distributor is a 180 out,just start the plugs wire number 1 directly across from where it is now,and if it is 180 out,it should be back firing .Now on adjustment of the lifters,after it is running,loosen each one at a time until you hear it clicking,then turn it down until you do not hear the clicking any longer,and add one quarter turn.If this was at all helpful,please rate,thank you.
Jul 19, 2010 | 1987 Chevrolet S-10 Pickup
Motorola Mobility att tl7610 dect 6.0 cordless headset Logo
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
