Question about Kenmore Dryers
Kenmore 417.84092500 will power on for cycle but when start button is hit the dryer makes a loud humming sound and does not tumble. How do I fix this?
Start Up issues
  • 33 Answers
This is a Frigidaire with the kenmore name. try turning the drum backwords to unstick the motor.
Posted on May 27, 2014
mikedurland
  • 481 Answers
SOURCE: kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Posted on Jun 28, 2008
  • 163 Answers
SOURCE: Dryer has trouble starting and makes a deformed hum sound
your motor is going bad.
Posted on Mar 08, 2009
Maytag317
  • 1136 Answers
SOURCE: start problem
Hi,If you hear the hum while you are pushing the start button and when you let off the button the hum stops, you have a notor going bad.
If you can get someone to help you, open the door, hold the door switch in, while someone else holds the start button, you try and turn the drum with your other hand. Sometimes the motor will start but, this only confirms the motor is bad and needs replaced. I hope this helps.
Thanks
Vic
Posted on May 15, 2009
  • 351 Answers
SOURCE: LEA30AW makes a humming sound when i hit start,
motor is most likely bad shorting out in the windings
Posted on Jun 26, 2009
miket756
  • 2702 Answers
SOURCE: dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Posted on Nov 16, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Barrel tumbles and everything dries but it makes a loud noise. Lessens slightly towards end of drying cycle.
is your laundry getting rolled into one big pack? My dryer does that and it sounds like someone is stomping their feet.
Mar 18, 2015 | Kenmore Dryer Sears Elite
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
I have a kenmore model #66512694 electric dryer. It will heat up fine and tumble but makes a loud humming noise and cuts off.
Sounds like the motor is over heating. If you have to wait a long time for it to come back on. If so you may be able to clean it but more then likely need a new motor.
Nov 12, 2010 | Dryers
When I push the start button the dryer will not start
May need to replace the starter swithch behind the control panel. MAKE SURE ALL POWER IS DISCONNECTED. If you still hear a humming sound when you hit the start button then it is not the switch, but the motor and if that is the case you may want to look into your warranty.
Aug 16, 2009 | Kenmore 63942 Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer has power won't start cycle
Hi, check first the power outlet , if still does not turn and motor humming during starting time , test the capacitor with multi tester, disconnect two wire of capacitor if not reading replace capacitor .
Jan 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
