Question about Gerber Venture Folding Knife 3.2 Combo Edge Tanto Point 7Cr17Mov Stee
How do you take apart a Gerber Venture
I need to take apart my Gerber Venture for some anodizing...it has those pretty 3 prong screws. Anyone have any suggestions please......
Gerber Multi - Plier 600 Needlenose: my knife broke on my gerber 600 a friend has an ol...
no need,send your knife to gerber and they will replace it.gaurenteed for life.
May 16, 2010 | Gerber Blades Multi-Plier 600 Needlenose
I need a shop manual and schematics for my Gerber Dimension 200 router.Great machine that happens to be sick right now.
http://www.devicemanuals.com/guide/Plotter/Gerber/Gerber-Dimension-200-router-Owner%27s-Manual-==TVRRMk5UTXk=.html
devicemanuals has a pretty good reputation for supplying manuals to technicians at home. Of course it has it's downfalls but at least the pdf prints and is legally distributed.
Apr 15, 2010 | Tools & Hardware - Others
Ignition switch
you pretty much have to take steering wheel apart the ignition switch is the part you put the key into its in their,your gonna need a manual
Feb 05, 2010 | 1999 Chevrolet Venture
HELP!!! I keep getting an f-02 error code
F-02 is usually the drain pump on Maytag and Whirlpools.
I would take the pump apart- it should have three screws that hold it together. It could be that the pump has something really small like a paperclip stopping the impeller. Once you have the pump apart, you can even (carefully) wire the two electrical prongs on the pump to an old electrical cord, (carefully connecting one wire to each prong) and plug it into the wall to see if it runs.
The drain pump works on 120 volts just like the wall outlet, so if it doesn't spin when you plug it into the wall it needs to be replaced.
Also, there should be a technician sheet inside the machine somewhere which might have some helpful troubleshooting tips.
I wouldn't advise taking the motor apart until you have tried a lot of other things first.
Mar 24, 2009 | Washing Machines
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
Broke my gerber 3.0 flashlight
Wow what entertainment. Both the poster and the bobint17 don't have a clue how this flashlight works... why answer a question you don't know the answer too? To screw with people? To sound like you know what you're doing?
Anyway, the Gerber TX 3.0 uses a Luxeon 3 LED. There is no bulb. It is not designed as a user replaceable item and unfortunately even someone skilled at soldering and such can't fix the light because the head is permanently attached and not designed to be removed allowing access to the LED assembly. Can the head be removed? Possibly. Will it damage something while trying to remove it with a lot of force? Possibly. Should you try? No. Why? Because the light has a limited lifetime warranty from Gerber. Send it to them and they will fix or replace it!!!
Feb 16, 2009 | Gerber Blades Gerber TX 3.0 Tactical...
3 prong to 4 prong on Maytag Neptune no heat no function
hi thanks for the question red to red black to black white to white green to the frame of the dryer thanks the appliance doc
Sep 28, 2008 | Maytag Neptune MDE6700A Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Gerber Venture Folding Knife 3.2 Combo Edge Tanto Point 7Cr17Mov Stee Logo
299 people viewed this question
Top Gerber Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Gerber Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
