Question about Calphalon 1779208 Slow Cooker, 7 Qt. Digital
E2 error code
Upon first plugging in my crock pot, it flashed an e2 code and began beeping. Wouldn't stop. What does this code mean?
Replacement of 2.5 crock pot container for three pot warmer
Crock-Pot® 2.5-quart Slow Cooker Replacement Stoneware
www.crock-pot.com/.../replacement...crock-pot-2.5...slow-cooker.../7110025100012....
Rating: 4.2 - ‎19 reviews
http://www.crock-pot.com/parts/replacement-stoneware---crock-pot-2.5-quart-slow-cooker--black/7110025100012.html. 7110025100012 ... Crock-Pot® Hook Up® Connectable Entertaining System 3-Piece Set, Metallic Charcoal. $124.99 ... Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. $9.99.
Slow Cooker Replacement Parts ' Crock-Pot
https://www.crock-pot.com/parts/ Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. 4.4 out of 5 stars. Read reviews. $9.99. 20% off Parts Use code: SPARE20. Free Shipping $50+ ...
Replacement Food Container w-Lid - Crock-Pot Lunch Crock Warmer ...
https://www.ebay.com > ... > Small Kitchen Appliances > Cookers & Steamers Rating: 5 - ‎1 review
Replacement Food Container with Lid - Crock-Pot® Lunch Crock® Warmer. ' eBay! ... Free shipping. Replacement Lid - Crock-Pot 5.5-Quart Oval Slow Cooker 129999-000- · Replacement Lid - Crock-Pot 5.5-Qu... ... $16.50. Free shipping. Replacement Stoneware - Crock-Pot 2.5-Quart Slow Cooker- Black 7110025100012.
Dec 10, 2017 | Crock Pots & Slow Cookers
West Bend Slow Cooker error code: "E01". - holding "cook" button while plugging/unplugging did not fix the problem.
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
Dec 22, 2010 | West Bend 84496 6-Quart Slow Cooker
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
I have a GE 168945 crock pot (walmart) and the lid broke. I can not find a replacement lid. I've checked E-bay and searched the web exensively for a 13x10 lid to replace the broken one. GE doesn't sell...
Please stop using your crock pot and throw it away!! I had one just like this and the heating element melted the bottom of the plastic base and nearly caught on fire on 02Nov2009. The only reason our home is still not a pile of burnt rubble is because my husband was standing next to it when it began smoking.
Seems there is a recall on this product and you may be able to return it to Walmart. Check the web for verification.
Oct 03, 2009 | GE 106851 6-Quart
When I plug in my 84596 west bend it gives me eo1 with a beep
The E01 error message happened to me this morning. I unplugged the crock pot, held the "cook" button and plugged it back in while holding in the "cook" button. It seemed to reset itself. It is working fine now.
Jan 01, 2009 | West Bend 84596 6-Quart Slow Cooker
All the lights are flashing
My father-in-law just Fonzied this one after a day of us all trying to fix the crock pot.
Press the "High-Low-Warm" button REALLY HARD. It's worked for us twice now.
Oct 12, 2008 | Rival 38651-C 6-Quart
Crock pot
I had the same problem this morning (E01 error message). I unplugged the crock pot and held the "cook" button while I plugged it in. It reset and all is working fine now.
Jan 22, 2008 | West Bend 84596 6-Quart Slow Cooker
Calphalon 1779208 Slow Cooker, 7 Qt. Digital Logo
176 people viewed this question
Top Calphalon Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Calphalon Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
