Question about Whirlpool Washing Machines
Top-load Whirlpool washing machine gets stuck on "sensing" stage of wash cycles
My top-load H.E. Whirlpool washing machine (model #WTW4950XW3) will not get past the "sensing" step on any wash cycle. Spin and Rinse cycles work fine, and I've run the rinse several times to clear any excess suds that may be there - this hasn't solved my problem. Any ideas?
  • Shelby Gensamer Jan 17, 2015
    did you fix your washer yet?
    New Friend:
  • 18 Answers
Hi my name is Charlie Lapinski. I will help you with your problem
is it locking the door at all?
Posted on Mar 29, 2014
Testimonial: "Yes, the door lock works, and goes through its regular pattern of locking it for a second, then unlocking it for a few, then locking it again to continue the sensing stage. Eventually (after 15-20 minutes or so) the lock will disengage, and the "wash" light will come on, but its clearly stuck here and won't do anything else (it's not actually washing, despite the indicator light saying that it is)"
  • Paul Sanden
    Paul Sanden Mar 29, 2014
  • gilbert_m_ga
    gilbert_m_ga Jun 19, 2014
    I read the last comment. So I tipped the machine over and took out the three screws holding the electric water pump in place. Behold, out came a baby sock and a hair pin tangled in the sock. It is working fine now-- thank you.
SOURCE: Fisher & paykel top load washing machine
We had the same problem with our washing machine being full of water and beeping during the rinse cycle. The problem is that the filter, which is located under the washing machine, is plugged with something. Ours was plugged with a cotton swab. You have to tip the washing machine up and remove the filter and unplug it. The filter is in the center of the bottom of the machine. It twists off. I had to get the cotton swab out of inside the machine through this opening.
This machine plugs up a lot - I've never experience this with any other washing machine. Good Luck!
Posted on Nov 07, 2008
  • 185 Answers
SOURCE: Brandt washing machine gets stuck at rinse
check the coupler it might be the timer
Posted on Mar 25, 2008
jonniewalker
  • 1031 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: hitachi top loader washing machine
Could be the safety switch which is faulty which is activated by closing the lid. There is a plastic section on the left hand side of the lid which activates the switch. The plastic lip on my model broke so i riveted a piece of alumimium in place
Posted on Apr 18, 2009
I have a whirlpool top-loading sensor washing machine model number wtw 4816 FW 0 my question is how can I get my machine to start agitating it's stuck on wash with a full load of clothes and the wash light...
I would get someone to check if the motor is actually in working order and at the same time check that the water pump is working as it needs to empty the drum in order to go to the rinse cycle other wise it cant move on eric
Dec 25, 2017 | Whirlpool Washing Machines
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
957 people viewed this question
Dan Webster
Dan Webster
Sal De
