I have a system with 7260-00 handsets and when someone calls in to a certain line, the line lights up on the set, but no ring tone. When it finally triggers a ring tone, the other person has already heard it ring 4-5 times before we here it once.
SOURCE: Setting time/date on Comdial 7260-00
Go to this website and it will give you the instructions on how to change the date and time on your comdial 7260. http://www.vertical.com/media/pdf/comdial_SAB007_DX80.pdf
SOURCE: I have Comdial 7260-00 that has stopped ringing
if u never droped it then go through the instruction book about ringing on or silent, if u do not have try to download it via google help
SOURCE: Change the line selected when lifting the handset (from #4 to #2)
that is not a user option it must be programed by a tech. it is a feature called idel line prefrence the other way iy can be accomplished is by using a hunt group but you will still need it to programed by a tech, you can contact me by email @ [email protected]
SOURCE: I have a comdial 7260 and the first line/ main
it would not be the first time verizon said it was a inside problem and it wasnt the only way to test it is call the number and answer the line before the system and see if it is getting to your location you can contact me and if you are in my aerea i can service it or if you are not i can refer you to a dealer in tat area
