Question about Oldsmobile bravada rivet. body moldings. cowl and dash panel. door
How is the door body moldings attached on the olds bravada?
Is it attached with double sided automotive tape, or are there some type of studs also?
    Sergeant:
  • 361 Answers
That suv for the few years that they made them it held on my doublesided tape , the best was to get it off is to heat it with a heat gun but be carful not to burn you paint , just do it on the molding itseld and it should come off with a strong plastic puddy knife so you do not scratch the paint and try to get most of it off with the gun then take a good paint remover and just clean the rest off do this very carfully so again you do not want to take the paint off the car , good luck
Posted on Mar 29, 2014
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
HOW TO REMOVE THE EXTERIOR DOOR BODY SIDE MOLDING?
Marisolis, I believe these molding are 2 sided taped on, patients, heat gun on low, firm thin plastic spatula,adhesive remover are required. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Remove Car Truck Door Molding
The Best Way to Remove Body Side Molding Adhesive eHow
Car Debadging Tutorial GMC Denali Truck debagding
Jun 06, 2012 | Jeep Liberty Cars & Trucks
2000 Toyota RAV4 side door emblems How do I remove, then replace [higher] RAV4 emblem on side doors to allow fitting of body protection mouldings.
Use an automotive heat gun set to low setting and gently pry the old molding off, then locate an automotive paint/body shop supply store and buy a roll of the special molding double sided tape to put it back on, you will have to buy a whole roll , it will be pricey.
May 18, 2012 | 2000 Toyota RAV4
Looking to replace passenger side mirror on a 2006 Town and Country. Anyone have Instructions available?
    Remove Old Mirror
  1. 1 Open the side door to the Chrysler Town & Country, and find thescrew that holds the side mirror molding in place.
  2. Take the screw out and remove the molding panel that attached around the outside of the power mirror.
  3. Remove the bolts connecting the mirror to the door assembly. If equipped, unplug the power side view mirror wiring harness connector.
  4. Unplug the electric connectors, and pull the mirror out of the molding.
Jun 01, 2010 | 2006 Chrysler Town & Country
2001 olds bravada airpump part PA66-M40 BROKE small vaccum attachment
that is not a part number for your olds, that is the number that was molded into the plastic part. pa66 is a plastic resin used on many automotive parts.
Apr 16, 2010 | 2001 Oldsmobile Bravada
I have a rattling sound in the dash passenger side that I only hear at around 60 and up MPH. Seams to be from some type of windnoise but I havent found anything loose in the dash.Has anyone else ever...
The side windshield moldings are your problem. Gm has an updated version but i wouldn't spend the money on them.
There are 5 screws holding the molding on. Remove the molding, clean both the window and the molding with a good glass cleaner. Put a strip of 1/2 inch double sided tape on the windshield edges then install the molding. This should take care of your problem.
Nov 11, 2009 | 2002 Chevrolet Silverado 2500HD
I need to know the distance that the drivers side mirror protrudes from the curvature of the door? and also if the outside drivers mirror is molded plastic into the frame of the car?
The outside mirrors attach to the door frame using 3 nuts that attach to studs that are part of the mirror. You can access the attachments by opening the door and removing the triangular shaped plastic trim piece, removing a piece of foam insulation and then you can see the three nuts to remove.
Oct 28, 2009 | 2002 Chevrolet Cavalier Coupe
Need to replace a broken window on rear passenger 1999 jeep chero
This information can help you to fix it:
- Section-08s-Power-Window-Systems-Ewj8s
- Section-23-Body-ewj23S (Rear Door, page 41 and next).
Good luck (remember rated this help).
Sep 09, 2009 | 1999 Jeep Grand Cherokee
Exterior vinal strip
not glue use what came factory on it meaning double sided tape. i kn ow that sounds dumb but double sided tape is actually a foam adheisive strip that is actually quite strong and more reliable and quicker than glue. just go to the local parts store and ask for it double sided molding tape
Aug 27, 2008 | 2000 Chevrolet Impala
Oldsmobile bravada rivet. body moldings. cowl and dash panel. door Logo
91 people viewed this question
Top GM Vehicle Parts & Accessories Experts
J.D. Browning
J.D. Browning
Chip Slate
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a GM Vehicle Part and Accessory Expert? Answer questions, earn points and help others
