Question about Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player
Wurlitizr remote for modelWR18
Need new remote for model wr 18 wurlitizer one I have will not operate the am fm radio or cd will not even turn the unit on or off
3 Suggested Answers
  • 834 Answers
SOURCE: Could some one tell me
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Posted on Sep 17, 2010
SOURCE: I have lost the remote
Try calling Deer Park Dist. (618) 427-3761. They have been able to get me bubble tubes and other front plastics. I'm not sure if they have a remote available, but it's worth a try.
Posted on Nov 02, 2010
How to Repair a CD Player on a Electro Brand Model 9222 Turntable AM/FM Radio with CD Player
not really repairable none of them are unless the laser itself died byut even then it isn't really repairable the only way would be to find the same type of unit and swap out the good cd player with the bad one but rather than go thru that just buy a new or nice used one no sense rebuilding this junk they really were throw away units it breaks/ you trow it out simple easist cheapest way out...buy another one used and be happy
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
Bose Wave radio
this is a power problem.
leave the unit unplugged for one night and then try switching ON
Oct 01, 2008 | Bose Wave Radio
The remote for my radio/cd player won't work any longAny suggestions? The model is: jWIN JXCD3250 Classic Style CD/AM/FM
Remove the batteries, clean the battery terminals with rubbing alcohol and Q-Tips and replace the batteries with new ones, if no! I would suggest you have someone look at it, usually find bad solder connections that need touch up.
Feb 13, 2012 | Jwin JXCD3250 Classic Style CD/AM/FM...
Need the remote control for Craig CM402 home stereo system with CD player and AM/FM stereo radio
Here is the link to the web page for Craig Electronics. The picture you will see is of the model you indicated and there is a contact number for Craig in the lower right corner of the screen. I am sure Craig will have replacements for the remote to your unit.
http://www.craigelectronics.com/site/pdetails.php?id=155
Oct 31, 2010 | Craig CD Shelf System with AM/FM Stereo...
I have lost the remote for my wr-18. Can I get a new one and how much will it cost?
Oct 24, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Alpine radio works fine, but only searches fm stations from 69 to channel 90. Most stations here start at 90 and go as high as 107.Radio is new, just bought on e-bay. traffic information is on AM!!!...
it sounds like you have purchased a unit that does not operate on our wave length, it sounds American, and all i can suggest is be careful where you buy things from mate, sorry, colin.
Dec 02, 2009 | Alpine MRD-M605 Car Audio Amplifier
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Radio switches between AM, FM, and CD
Check fuse no. 18(20 amp) in the under dash fuse panel. This is the fuse that keeps power to radio at all times to keep memory alive.
Feb 04, 2009 | 2006 Ford Fusion
Power off and on again and then no sound present
i assume pressing the source button on the remote control is how you normally turn it on again, (ie video FM CD etc)
it might be that moving the unit to the cabinite the battery power in the remote ( its not infra red its radio wave thay are not picked up by the fm antenna ) is insufficient to wake it up again,
change the batteries in the remote or try to see if there is some weird reason the cabinet is preventing these remote control radio waves from being recieved by the head unit, try opening the door and bring the remote within a few inches of the head unit and see if it turns on when you pres the cd button.
see how you go from there mate
Nov 30, 2007 | Bose Lifestyle 12 System
Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player Logo
49 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
