Question about Eclipse New 180rd 4gb 4gb Portable Media Player With 1.8" Display
Always says it is connected to usb and will not communicate with computer
Accidentally left it linked to computer and shut computer off, now it says it is always connected to usb and when i really do plug it in nothing happens and the computer won't even recognize it
What does Communication Error mean?
I am guessing that you are using Windows 7. If so go to Control panel 'Hardware and Sound' Printers and select Remove a Printer. You may then unplug the printer usb connection and restart your computer. When the computer has restarted , you may go to the link below to download the most current drivers and install them .
Do not plug in the usb connection until you are told to do so. Also, the printer may select a default connection to LPT1 , which is a parallel port connection (apparently this printer likes to do so , and this will give you your "communication error" ). If it does, go to printers in control panel (see above) , right click on the icon for your printer , select "properties" , and left click on the " ports " tab. Make sure that the port selected is USB001 or similar and NOT LPT1.
Epson Stylus Photo R280 Ink Jet Printer
Aug 16, 2014 | Epson Stylus Photo R280 Series
No Connection
Hi Norm,
First, try a different USB device in the USB Ports, to make sure they are not disabled.
Uninstall the DWL-G120 Drivers, in the add/remove programs. Unplug the device. Download and install this program.
http://www.nirsoft.net/utils/usb_devices_view.html
Click on Options, check each one. Click on all instance of the USB device you want to remove, (Marked Disconnected.), and under File, click on Uninstall Selected devices You can hold the CTRL key to select more than one.
Once they are all cleared, Open My Computer and go to C drive. Delete any folders left over from the DWL-G120.
Reboot, and reinstall the drivers, and plug in the device.
If that don't work, you can try a different USB port for it.
Good Luck!
Jan 07, 2008 | Computers & Internet
My computer doesn't appear to be communicating with my printer. I am utilizing a usb cable and port. Is it possible that my printer USB port or modem isn't operating correctly??
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Samsung CLP 300 Laser Printer
"Communication Error" message
Use a card reader to download your pictures to a folder you create on your desktop.
Sep 29, 2009 | Fuji FinePix A360 Digital Camera
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
Jul 20, 2009 | Lexmark X3650 Printer
Communication error
Sounds like you have corrupted or possibly deleted a Fine Pix Viewer driver software file.
Suggest you uninstall and reinstall Fine Pix Viewer.
Before you start you might want to create a backup folder on your C drive and put copies of all your photo files therein. Make sure your camera is not connected to your PC before reinstalling software.
Assuming Windows operating system click : Start, Settings, Control Panel, Add or Remove Software, then scroll to Fine Pix applications. You will probably have three to choose from. Since you don't know where the problem lies suggest you start with Fine Pix Viewer which will probably have a version such as 5.5 (in my computer anyway). Having highlighted this file click on the uninstall button.
Now reinstall from your Fine Pix CD.
Suggest you reboot so new software will recognise your camera when it is connected. With camera connected Windows will probably advise that there is new hardware and it is seeking software. Give it time and Viewer should boot up on your screen.
Jun 12, 2009 | Fuji FinePix Z100fd Digital Camera
Hi Folks, Had my camera just over a year. Put it on today to take photos and it has come up, WHITE SCREEN, USB LOGO TOP LEFT, THEN SAYS COMMUNICATION ERROR. And thats it, cannot go any further ! I have...
pls try to update ur firmware of camera from this link if the problem persist then take it to fuji customer care centre
http://www.fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=872619&prodcat=234644&sscucatid=664260
pls rate FIXYA for the help if u like
Mar 15, 2009 | Fuji FinePix S5700 Digital Camera
GPS to software communication issue
look in the options of the software ... choose auto or usb for communication with the garmin
Jan 10, 2009 | GPS
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
Desk top APC UPS ES750 not communicating
Here is an answer I got from APC when one of my client got the same problem as you did:
The error message would pop up if the link between the computer and the UPS is weak. I cannot rule out a problem with the cable or the UPS. In order to confirm the same please try the following steps which might help :
1) Ensure that the USB cable is properly connected to the USB port of the computer.
2) If the PC was powered on before the UPS, communication will not be achieved until you disconnect and reconnect the USB cable to the host. In this case, you need to disconnect and reconnect the USB cable to establish communication.
3) Some other software is polling your USB port for another device, thus causing the UPS software to temporarily lose communication with your UPS. If this is the case, you would need to shut down that application.
4) If you have any other USB devices connected to the PC, disconnect them and then try plugging in the cable.
If the issue persists, please visit the following link which lists few troubleshooting steps :
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=oXhRFGEh&p_lva=&p_faqid=2923
Dec 13, 2007 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
Eclipse New 180rd 4gb 4gb Portable Media Player With 1.8" Display Logo
143 people viewed this question
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
