Question about Home
Glacier bay dual flush toilet
Fills slower and slower. Is there a filter or some place in the line that is easily blocked?
  • Mark Sprague
    Mark Sprague Mar 29, 2014
    Fixes! Water feed pinched where it goes into the filling tube. Pushing it all the way down decreases the pinch.
  • 102 Answers
SOURCE: I recently bought a Glacier Bay 303-635 All-in-One
Try adjusting the water level down about a half inch or so and see if that helps. It could just be siphoning. Otherwise the valve may be defective. Hope this helps.
Posted on May 11, 2010
  • 349 Answers
SOURCE: how do i set the flush levels for a glacier bay
http://www.homedepot.com/catalog/pdfimages/f9/f9b2dcf2-bfa0-4622-94d9-7b326c22eb1e.pdf
Go to page 5 & 6 and it will guide you through setting levels.
Posted on May 23, 2010
SOURCE: I have a Glacier Bay
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Posted on Aug 20, 2011
kachbibi1
  • 979 Answers
SOURCE: i have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Posted on Feb 24, 2013
pvaz1946
SOURCE: glacier bay gal toilet.
Buy American!
Posted on Apr 02, 2013
I just installed a new glacier bay dual flush toilet. The tank won't fill unless I lower the fill valve by hand. Then it overflows the intake tube.
Make sure that you have installed everything correctly. Have someone else go over what you did because returning that thing is a PIA!!!!!!!!!!!!!!!!!!!
Sep 16, 2017 | Glacier Bay Home
Where can I get a replacement handle/flush lever for a 2006 Glacier Bay 1.6 gallon toilet?
Glacier Bay Toilets are made in China by "various manufacturers" a local plumbing parts supplier is your best bet.
Jan 11, 2016 | Home
Glacier bay n2316
http://www.youtube.com/watch?v=lbU80u1mpUM
Mar 09, 2014 | Plumbing
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Feb 23, 2013 | Home
Where can I find replacement parts?
home depot etc, most hardware stores.
Mar 30, 2012 | Home
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
Jan 28, 2011 | Home
Glacier bay gal toilet.
Does the tank lid have a seal on it to keep water from coming out?
May 30, 2010 | Home
I recently bought a Glacier Bay 303-635 All-in-One toilet. It was installed just fine, however everytime I flush the toilet the tank fills up to the water line, but the spout over the water line tube keeps...
May 11, 2010 | Home
Home Logo
46 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
