Question about Apple Iphone A1387
Will not turn off
Battery will not hold a charge and when i press the button to turn it off it will not stay off
  • 35 Answers
There may be a problem with your power button. See a technician to look at it and replace if neccessary.
Posted on Mar 30, 2014
Motorolla walkie talkie shuts off when PTT button is pressed... Driving me INSANE. Please help
This is usually a low battery issue. If you are using the rechargeable battery pack, does your Motorola unit accept regular batteries in place of the rechargeable battery? If you can put in 3 or 4 AA batteries (depending on the model), try that. If the radio stays on when you press the PTT button, then continue using the regular batteries or get a replacement rechargeable battery, if you can find one for the model. If the radio still turns off when you press the PTT button with fresh batteries, then replace the two-way radio.
I hope this helps. When the rechargeable batteries fail, they will still charge but they won't hold a full charge for as long a period.
May 20, 2018 | Radio Communications
My t mobile vivacity wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 30, 2012 | Cell Phones
Can't get Nexus 7to turn on
5.Wait 10 seconds.
Step
Thanks
Dec 01, 2012 | Cell Phones
My LG pdp42x3 plasma doesnt turn on.
5.Wait 10 seconds.
Step
Thanks
Oct 02, 2012 | Cell Phones
My phone won't turn on
5.Wait 10 seconds.
Step
Thanks
Sep 14, 2012 | Apple iPhone 4 Black Smartphone
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
No power to my ICN 520
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Jun 08, 2008 | Navman iCN 520 GPS Receiver
Apple Iphone A1387 Logo
55 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
