Question about Samsung Televison & Video
I have a Samsung BD-FM59 Blu-Ray player which is currently connected to the internet by wifi. I watch Netflix with it. Periodically, it loses the connection and I have to reboot the Bluray player in
Loses connection using wifi
  • Pat Byrd
    Pat Byrd Mar 31, 2014
    I disconnected the wi-fi and hard wired it with an wthernet cable. Ploblem solved!!
  • 5 Answers
SOURCE: blu ray want connect to the internet
You have to buy a Samsung wireless adapter in order to use a wireless conection..look up your player at www.avsforums.com for any and all questions and answers.
Posted on Nov 16, 2009
  • 6 Answers
SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
Posted on Jan 10, 2010
  • 4 Answers
SOURCE: DVD playback distorted in Samsung BD-P1600 Blu-ray Player
I called Samsung with the same issue. After verifying the latest firmware was installed, they suggested I send the unit in for service. I expect it back sometime this week, and DVD playback will be the first thing I test.
Posted on Apr 14, 2010
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
buddyglee
  • 65 Answers
SOURCE: what is the Netflix activation code
My netflix stopped working cause I didn't update my Credit card info when I got a new card.
I can browse Vudu just fine but after getting billing info correct for netflix, Doing a system factory reset of the visio I still get a Not connected to the internet message when trying to start Netflix.
Posted on Nov 15, 2012
Why does my m55 loses wifi connection?
Your other devices all buffer the signals internally. Your TV does not. Any disruptions in the continuity of the wireless signal show up as pauses and breaks in the streaming.
You can spend time trying to diagnose, and then changing WiFi channels But quite honestly, if you have neighbours who don't know or care about wireless then any fix you do will be undone because they'll just trample over your signal again.
Either go with a bit of cable (Ethernet cable) from the router to the TV, or buy some Ethernet of Power adapters (Homeplugs) and use them. Beware though, homeplugs radiate quite a bit of energy because they use the unshielded mains cable for transmission. They aren't as quick either as Ethernet cable direct because of the lag from the encryption/decryption and error correct processing.
Sep 06, 2014 | Vizio M551d-A2R 55" 3D LED Smart HDTV
Can't stay connected to wifi
reinstall windows or go back to factory settings.
Jun 04, 2013 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
Connections lost lumia 800
your lumia 800 is ok and working fine. there is problem with your internet connection or your wifi modem. your modem's internet setting may have been altered by someone by mistake. your pppoe user name and password may have been deleted. when you will connect wifi to your lumia, then sometimes it will automatically start internet connectivity test. if this test passes then your internet will work fine, if it loses then you cannot use internet.
Apr 11, 2013 | Nokia Lumia 800
Sony vaio loses wifi handshake
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 24, 2013 | Sony Computers & Internet
I have a samsung corby and i always connect to the internet using its WIFI, but what i've noticed is that whenever i try to download a file or watch videos from Youtube, it loses connection and the WIFI...
i have also a samsung b3410w and my situation is same but i have also a nokia n97 and it is a smart phone what we call a symbian phone and it does not do what samsung do i always use my n97's wifi and watch videos on youtube {i think that samsung's wifi can't stay connected with wlan}there is no solution of this problem
u can only do one thing
and
that is
just enjoy your life
Feb 13, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
LG Incite wifi loses connection when using browswer
Find Proxy Manager select <Disable Proxy> and hit <OK>
Proxy Manager is located in the Tools folder
That weird button (four dots with a finger and hand) on the bottom right
Calculator Tab
bottom right Suitcase looking icon called <Tools>
Or you can find the Proxy manager the hard way by going into
File Explorer>My Device/Windows/ProxyManager.exe
Feb 14, 2009 | Computers & Internet
Televison & Video Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
