Question about Sewing Machines
Kenmore 385.16231301 sewing machine
Power to light, but not to motor. Have purchased a new lead cord and control. Problem still unresolved.
bargainbox
  • 1388 Answers
SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by itself....as to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
Posted on Feb 10, 2008
  • 18 Answers
SOURCE: I need to replace the motor belt on a Kenmore sewing machine
You can find the belt you need here:
http://www.sew4less.com/QuickSearch.php
if not in stock try here for the part you need:
http://www.a1sewingmachine.com/belts.html
Posted on Jul 07, 2009
  • 3741 Answers
SOURCE: Kenmore 158.1703 sewing machine - needle not going up and down
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!. also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 05, 2010
SOURCE: Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Posted on Oct 10, 2011
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
Where can I purchase a used Sewing Machine Foot Control Pedal & Cord
Try eBay or a sewing machine repair service.
Search the internet, inputting:
Manufacturer + Model + "parts"
Aug 16, 2014 | Kenmore Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
Some times the electrical connection works and other times it does not, i have had the cord replaced
It could be the electrical connections at the sewing machine, and not the cord. Does the light come on? Does the light stay on when the motor stops working? This could indicate problems other than the cord.
Derek
Jan 15, 2011 | Kenmore 756A-30BH Mechanical Sewing...
Elna supermatic...the light comes on ,,but nothing else works
Turn the machine on, press the foot control down and turn the handwheel backwards. If it sputters, the motor carbon brushes are worn to the springs and need replacing.
Next, while pressing on the foot control, try wiggling the wires around where it enters to machine and where it enters the foot control. There may be a short in the cord. If the short is at the machine, you need a new cord. If it is at the foot control, the cord can be pulled into the foot control, the shorted part cut off and the connection reattached.
If it still doesn't work, try removing the cord from the machine and placing an alligator clip test lead to two of the inlet prongs on plugging it into power. Which two prongs you ask? Try several combinations, (one will light up the lamp) CAREFUL: THE MACHINE MAY SUDDENLY TAKE OFF AT FULL SPEED, SO REMOVE THE BOBBIN, THE THREAD AND NEEDLE FIRST. if it runs, it is your foot control. If it doesn't run, it's likely the motor brushes or motor.
Dec 11, 2009 | Elna Sewing Machines
No power to my machine I think I need a new foot control for varimatic 6091, the light won't come on is why I think its the power cord.What do they cost, how soon can I get one.
if its a sealed plug,do a continuity test from one end of lead to the other after removing power lead,suspect damaged lead at plug/socket ends
Nov 18, 2009 | Sewing Machines
I have lost my power cord to my Janome model 5024 sewing machine
There are several location where you can purchase a power cord for you machine, Here is an online source, Hope this helps
http://sewingpartsonline.com/power-cord-kenmore-385-12916-sewing-machine.aspx
Aug 16, 2009 | Janome Sewing Machines
Light dims when you sew
the problem is that the cord that was replaced on it is too light for the sewing machine. some companies sell cords that are made with 18awg wire 18awg wire can only deliver enough electricity to run the motor sapping up all of the power from the light as soon as you push the pedal. you need to get a cord made by singer or rewire your cords with 16awg wire... 16awg wire is the standard wire for all vintage singer sewing machines it keeps the light nice and bright...... hope this helps
Aug 06, 2009 | Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
