Question about RCA DSB772WE Wi-Fi Streaming Media Receiver
No connection but to rca ssb772we streaming media box
When installing player i lost internet but to the media player how do i fix it with out aggervating comcastr???
2 Suggested Answers
lilprince634
  • 4 Answers
SOURCE: rca media streaming player won't turn off or on with remote
Don't worry mine's a piece of **** too. When I have that problem I just unplug it and plug it back in a few times and eventually it will turn on by itself when you plug it in. And by then the remote usually starts working. If not then I suggest pushing down on your battery while holding the remote pointed STRAIGHT AT the box. That usually does the trick even though its a HUGE pain in the ***.
Posted on Oct 08, 2012
Why does my roku keep Turing off and on???? ??????
Does it shut off or constantly buffer?
You may have a bad connection check plug on ROKU box.Also check your HDMI or RCA (red white yellow plugs )CONNECTION.
Check batteries in remote ,take the batteries out or rotate batteries..
You may also have a very poor HDMI signal either because of slow internet speed or a weak router.
Feb 15, 2016 | Roku Televison & Video
How do I add the internet function to my Roku streaming media box?
go to settings then internet connection, pick your wi-fi put in password and your done
Nov 06, 2014 | Roku Televison & Video
Can't get to Netflix - stays at privacy policy statement
My sister is having the same problem with her RCA box for the last 24 hours.
Mar 06, 2014 | RCA DSB778W Wi-Fi Streaming Media Player
How do you connect a RCA router to a Sansung HD TV with Xfinity update
Mary, if you have internet, you will have a modem device. This device may be part of the router or it may be a separate unit. In any case, once this is determined and your internet is shared you will be able to connect your tv to your router. Your tv may be a wifi compatible set or not. Depending on which type of set you have, you will either connect a cable to the router or you will have to set up wireless. Wireless will be configured on your router. Once this is done, you can configure your tv to use the wireless connection. For more information, I will need exact make and models of your modem, router and tv. Also, google is a great source for documentation. If you decide to tackle this on your own, set up your modem, set up your router, then set up the tv. Hope this helps.
Oct 06, 2013 | RCA DSB778W Wi-Fi Streaming Media Player
Rca media streaming player won't turn off or on with remote
May 06, 2012 | RCA DSB772WE Wi-Fi Streaming Media...
How to install RCA streaming media player on an old TV
I've had a quick look at some instructions online, can't be sure if I'm looking at the same device as you but.
Guesstimating, you're connecting via the composited A/V jack out from your box to RCA (red,yellow,white) inputs on your tv. Or the same but using a SCART converter.
If so, once you've turned it all on, you probably have to change to the correct AV input on your TV. Just keep pressing the AV button on your TV remote control, it should cycle through all the AV inputs until it gets to the one you require.
Apr 28, 2012 | Audio Players & Recorders
When playing sample songs in ITunes the songs pause and an "Opening URL" message appears with a message "rebuffering stream" in the box. I have looked for answers and some say the media player is the...
this is not a problem from the media player ..it is a connection issue ..when the flow of the packets into the connection streaming is not continuous ..its makes what is called under-buffering and will stop until the information are streamed again in the right way..This is happening only with songs you play from the internet or the itune storenot with ones already downloaded..
Jun 01, 2010 | Apple iTunes
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Sep 18, 2008 | Computers & Internet
RCA DSB772WE Wi-Fi Streaming Media Receiver Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
