Question about BenQ SP831 Projector
Projector keeps blinking initialization light and won't power up lamp
Every component works, but the projector won't finish initialization when switched on by powering the lamp. Lamp can be powered manually by pulling lamp-on signal to ground, but then a lamp error code "fan initialization error" shows. Also forcing power on the fans using fan signals won't help with the error.
  • Chiri
    Chiri Mar 31, 2014
    I organized a second working SP831 and exchanged each component except the main board and the boot-up hang is still there. Power up sequence: 1) orange-orange-orange downloading firmware, 2) green-dark-dark ready, 3) pressing power button, 4) green blink-dark-dark forever
  • Chiri
    Chiri Apr 02, 2014
    Pressing the SW3 on the mainboard during initialization phase (green blink) causes the projector to boot up, power lamp and fans and working flawlessly. I have no idea what this SW3 is, I just have to press it every time turning on the projektor for now.
dhiman
  • 115 Answers
SOURCE: LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Posted on Nov 19, 2007
SOURCE: Projector shuts down after only a few minutes.
enter in Factory Menu
1. How to enter factory menu:
I. Hold press "UP" button until the "Lamp hours info." OSD display on bottom-right of screen.
Press keypad <Power> and <Blank> key simultaneously again, then enter Factory menu.
enter in fan menu and increse the speed of fans.
paul@ula.ve
Posted on Jul 02, 2008
Had the same problem with PB2140, during startup the lamp went off and power and lamp leds turned on. This happened after the projector fell down. I read a post there hat mentioned it was probably the power supply so i disassembled the projector. I found out that a small transistor of the power supply was torn away but it was still inside the projector. I found it, put it back and the projector works just fine. Thanks!
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
rulds2008
  • 3866 Answers
SOURCE: Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Oct 23, 2009
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
PG-MP60X - Power light is red, lamp light is red, projector not working. How I can fixed that ? thank you
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 04, 2014 | Sharp PG-M60X Multimedia Projector
Both red warning lights on the projector are blinking.
how about the fan does it works, then clean the filter.
Jul 18, 2012 | Office Equipment & Supplies
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
REPLACED LAMP, LAMP LIGHT STILL BLINKS
If by blink you mean it flashes on then goes out, it could be the lamp ballast. It puts out an initial high voltage to spark/start the lamp, then drops the voltage to keep the lamp lit. It could also be the power supply that feeds the ballast. If it is actually continually blinking, it could still be one of those componets. If there's a warranty, call the vendor for instructions, or you'll probably have to have it serviced/analyzed.
Feb 09, 2011 | InFocus Proxima DP8400 Projector, Factory...
I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 02, 2010 | Sharp REPLACEMENT LAMP FOR XR30X/30S/40X...
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
There is no picture when i hit the power. the lamp light blinks once. also the lamp is pretty new.
Just from your description, the problem sounds like a "ballast" problem. That's the circuit that controls the lamp. It initially ignites the lamp and then keeps it burning. Just to be sure, remove the lamp and inspect it. There should be no dark spots on it or bulges, etc. Since you have a new lamp, chances are low that it would be bad--if possible, return to where you got it from and test your projector with a known-good lamp. Classic ballast failure symptoms are just what you described...Is the projector under warranty?? Normally the ballast is over 100 to several hundred dollars depending on make, model, etc...Rick
Sep 06, 2009 | Optoma DX605 Multimedia Projector
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
BenQ SP831 Projector Logo
32 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
