Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Leaking at tub
Water leaking at the bottom of the tub
    Problem Solver:
  • 18 Answers
You might need a new inner tub. you can order a new one at www.repairclinic.com. you can click the second blue link to order.
http://www.repairclinic.com/PartDetail/Inner-Tub/W10296143/1553051?modelNumber=WTW6600SB0
Posted on Mar 29, 2014
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
When driaining out water comes out
Where does the water come out from? From under machine or where the drain hose hooks to the drain. If it is coming out the drain where the hose hooks the drain is most likely stopped up. If coming from underneath could be a hose or the pump leaking. I have seen something like a screw get caught and wear a hole in the tub. Check around the bottom of the tub if there is water leaking around the bottom of the tub could be the tub seal is bad. Hope this helps.
Dec 23, 2010 | Washing Machines
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
Leaking from the kenmore washing machine
Any part of the machine that has water contact is a possible source of the leak. Look for the highest (elevation) wet spot--that will be close. The tub has a couple of rubber connections--one on the side for water level sense and another for water drain on the bottom. If the tub itself has a rusted out spot, it can be repaired with epoxy cement (from inside the tub). It will be necessary to remove the inner tub assembly to get to the outer tub.
Jul 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
