Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Ice Maker not dispensing, auger not running
The ice maker is producing ice, but the motor that turns the icemaker to dispense ice is not running.
  • Official Brand Answer
  • 2,267 Answers
Hi Zack, this is AP!
I understand you are experiencing trouble with your Frigidaire refrigerator not dispensing ice from the dispenser on model#PLHS267ZA. First, check to see that both doors are closed. The dispenser will not operate if the freezer door is not closed to make the safety switch located where the door meets the outer wall of the freezer. Close the door and make sure nothing is blocking the door keeping it from closing. Another troubleshooting tip is to disconnect the power to your refrigerator for 5 minutes, then reconnect and try to dispense ice. If you are still experiencing the same problem there could be a problem with the motor releasing the ice. If your appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information helps to some degree.
Best of Luck,
Posted on Apr 03, 2014
  • 32 Answers
SOURCE: Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Posted on Jul 04, 2007
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
tborn6
  • 700 Answers
SOURCE: ice maker will not dispense ice
your gpoing to have to thaw out the pan that has all the ice in it the the auger will work
Posted on May 24, 2009
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Feb 09, 2016 | Refrigerators
Why is icemaker making a clicking sound?
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
