Rreplacing a ignition module on a ford f150 truck
Sometimes will start sometimes will not
    Master:
  • 680 Answers
You should repost this in automotive.
Terry
Posted on Apr 03, 2014
F150 Ford Truck
What year? Try looking under distributer on side. You will have to mark the distributer then loosen to turn it to get at ign module. Also you may need a special tool available from local parts store. After installation you will need to turn distributer back to mark you previously made for timing.
Jun 15, 2013 | Vehicle Parts & Accessories
Ignition module 1991 ford f150 issues
Ignition module? Are you talking about the one in the distributor the hall effect stator Or.The pick up? or the module on the side of the distributor.
Mar 08, 2012 | 1991 Ford F150
I have a 91 ford f150 starting to have engine problems when is running on the street the engine shuts off
If it has to set for a little before starting back up replace the ignition module.
Feb 09, 2011 | 1991 Ford F150
1988 Ford F150 5.0 .When at a stop wants to go dead. at the speed of 35-55 and at 65 the truck will start to ****. I have changed the spark plugs changed the rotor in the distubor
Mine did the same thing. It has something to do with the ignition module in the distributor on mine. Sometimes on those models the distributor goes bad and doesn't throw a check engine light. The ignition module may be a good place to start considering the part is only $40 dollars and takes about 10 mins to change. On the front of the distributor right at the base. (frnt of the motor)
Nov 23, 2010 | Ford F-150 Cars & Trucks
Wont start or has problems starting
Chek fuel filter first, and replace if it hasn't been changed in a while. Then if it still has problems starting, check ignition module. Make sure all grounds are tight and making good contact as well.
Aug 19, 2009 | 1990 Ford F150
Truck cuts off while driving down the road.
Replace the TFI module. Ford back in 1986 thur 1993 had problems like the one you wrote about. TFI module gets hot and shuts car or truck off then when it cools sometmies starts and sometimes not.
Jun 14, 2009 | 1993 Ford F150 SuperCab
1995 F150, 5.0 ltr. Always starts when cold. Drive
If it has the ignition module attached to distributor with 2 small hex head screws, and plug in harness to it. ( 4'-5" long x 1-1/2"- 2" wide approx.) I would change it. That was a common symptom of those.
Apr 05, 2009 | 1995 Ford F150 Styleside Regular Cab
My 1990 F150 will not start sometimes. If I turn the switch to the on position and the fuel pump continues to run after 5 Sec , It will not start. If the pump stop running after 5 Sec , it will start.
when u turn the key to run but don't start the fuel pump shuts off after 5 seconds + or - 2 seconds, this is normal, the common cause of no start on your truck is the TFI ignition module on the distributor, subject of many recalls for failing, also change the stator inside the distributor, use factory parts, aftermarket parts fail very quickly. here is a picture of the parts.
da17e03.jpgThis is the stator
This is the TFI ignition module.
Apr 02, 2009 | 1990 Ford F150
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
