Question about Marantz Audio Players & Recorders
Left channel static
I have a 2238B with static coming from the left speaker. It is present regardless of source and there is more when I adjust the volume or balance. It is present when there is no source signal as well. It goes away completely when I use mono. Any help would be greatly appreciated.
    New Friend:
    Problem Solver:
  • 5 Answers
I have seen dirty switches or pots cause constant static. I would get some contact cleaner and try spraying it into all switches and pots, and work them to clean the contacts. Also, check to see if there is static in a low-level output such as the one for a tape recorder.
Posted on Apr 26, 2014
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
  • 54 Answers
SOURCE: No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Posted on Feb 25, 2007
robotek
  • 1512 Answers
SOURCE: nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Posted on Feb 06, 2008
petraman7
  • 1175 Answers
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
VOTIT
  • 2071 Answers
SOURCE: technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Posted on Jun 08, 2009
I have a marantz 2238b receiver and a magnasonic dvd 824-2. . where do I connect the cable to watch movies?
To play audio from your DVD player through the 2238b, you will need to hook the RCA left an right outputs from the DVD to the Aux IN on the back of the 2238b. Then you will need to power on the 2238b and place the selector switch to the Aux position. Lastly, adjust the volume to a level you are comfortable with and that should be it.
Thanks
www.back2lifeelectronics.com
Dec 09, 2013 | Marantz 2238 B Stereo Receiver Classic...
How do you get the RX icon to turn off? The unit just has a contant fuzzy buzz.
RX represents "receive" This indication will be present whenever the speaker is producing audio. The "buzz" you're talking about is probably static, and is technically audio from the speaker. To silence the "buzz" adjust the squelch just until the speaker falls silent. The RX indication should be off at this point.
It is important to note that the squelch is designed to keep the speaker silent until a signal is detected. You adjust the squelch based on the level of static at a particular time and at a particular location. The static level may change depending on those variables. If you adjust the squelch well beyond the point that the speaker is silenced, you may not be able to hear transmissions or calls to you unless the caller's transmitter is physically close to you. This is why the squelch should be adjusted only until the static is stopped and the speaker is silenced.
I hope this helps and good luck!
Apr 30, 2012 | Radio Communications
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
Left Channel does not work. Subwoofer and Right Channel work fine. The plug needs to be plugged into the brown jack on the front of the computer to work at all.
Sort of sounds like there's a PC in the mix.
Can you swap the left and right speakers to isolate the speaker from the source as the problem?
Have you tried switching the various plugs around to isolate if anything comes out to the Left Channel, ever or if any other speaker plugged in as the Left works at all? Turn the volume down and bring it up slowly at first because if you send Subwoofer programming to a speaker not designed for it you may damage it.
If nothing works when plugged in as the Left speaker, maybe the sound card is the problem. Resubmit a question with the source or the PC as the problem
Nov 28, 2009 | Altec Lansing VS4121 Speaker
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Terrible static on left side of all channels
Hi...
Unplug all the inputs to the amp.
Does the problem go away?
If its only the left sometimes, it sounds like the speaker selector switch or source selector switch needs a good cleaning with some de-oxit and a small brush
Apr 27, 2009 | Audio Players & Recorders
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
93 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
