Question about Edifier Audio Players & Recorders
Edifier M1310 THe problem (How CONNECT copper wire in a piece of board that controls the pitch of the voice. Or on off sound )
Edifier M1310 multimedia speaker
4 Suggested Answers
  • 4 Answers
SOURCE: Speaker Output
hi this is vijay , it is not ur speaker prob , it is ur music player prob, plz use k-lite codek pack 3.0. and i hope it will slove ur prob.
thanks
Posted on Mar 17, 2008
  • 9 Answers
SOURCE: just reformat my pc and can't hear any sound now.
Audio drivers are not installed just see your pc company name and search in google for its audio drivers and after downloading them install them and restart the pc and then you can play the audio.
Posted on Apr 04, 2010
bronk50
  • 27725 Answers
SOURCE: I want to use my edifier computer speaker for sound output. While i am connecting my PC to LCD through HDMI cable i cant able to hear any sound.How i need to connect this
you might need to buy a 1 audio to 3 plug lead adapter im not sure on your sound setup
this might guide to a solution
http://www.ebay.com.au/itm/1-2m-3-5mm-Jack-3-Phono-Composite-Video-Audio-Cable-/380294606189?pt=UK_Computing_CablesConnectors_RL&hash=item588b532d6d
hope this helps
Posted on Oct 19, 2011
Tip
Military Antennas
In the Army you are out in a field with a radio, a copper wire, a metal stake, and you pitch a tent. Its a radio similar to Cb radio 2 ways. You can run a wire 34 feet across between two trees about 15 feet up. make sure you tie the wire at both ends with Nylon rope(plastic) to the trees. Take the 4 to 6 feet metal rod drive into earth(ground). Attach center coax piece to wire strung between trees at one end. Attach shield to Ground Rod. Another way is to nail a board about 15 feet up, attach a copper wire 34 feet going out one way and another 34 feet the other side. It will form a Pyramid. Tie to two stakes in ground at both ends with nylon rope. It will make do for a fast Cb radio emergency camp radio. It may get stations 15 to 30 miles away. Try camping on a Mountain top with a portable 12 volt battery,Mobile CB, Copper wire, Metal stakes,plastic rope, Square plastic piece 14 inches long or a board piece.
on Apr 01, 2011 | Radio Communications
200w audio power amplifier
sounds like it's getting really hot, that round thing your talking about is kind of a step up transformer which causes inductance and will increase the voltage that the other components need to run properly. It's copper wires wrapped around a piece of iron like an electromagnet. So what is you question?
Aug 07, 2013 | Car Audio & Video
I have control pcb on my bryant hvac home unit. HK42FZ009 blows F1 24 3amp fuse. It happened about a year ago and replacing the fuse solved it until now. New fuse blows immediately. Looking for...
Take everything off the board. With power on and carefully, one by one put all components back on until fuse pops. This will narrow it down. Obvious short to ground in one piece. Verify 24 volts from transformer.
Aug 05, 2013 | Bryant Heating & Cooling
Just reformat my pc and can't hear any sound now. maybe a installer for Edifier M1310. thanks
Apr 04, 2010 | Audio Players & Recorders
My tv mini circuit board where I connect the cable cracked is that fixable?
Depends on how badly is cracked. Open the case and hot glue (use a lot, it must be big enough not to melt later) the broken pieces from the parts side. After that you will have to restore the printed circuit board: scrape gently the lacker from the copper wires from the board and solder some additional wires on top of them.
Nov 26, 2009 | Office Equipment & Supplies
RCA HD52W59 power light on for 10 seconds then off
Possibly the HV splitter as that set is also famous for bad splitters.
Sep 29, 2009 | RCA HD52W59 HDTV Projection Television
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
When listening to podcasts the voices sound weird
Try updating the drivers for the soundcard. The pitch change could be a sampling rate error.
Apr 17, 2009 | Audio Players & Recorders
HIGH PITCH ON VOICES
This is possibly a sound card issue. Your card may itself may need updated drivers. Go into device manager and find your sound card and see if they have any updated drivers from there website. If you happen to have another sound card throw it in and see if it does the same thing. Last but not least is these speakers will work with a MP3 or other device, plug into them and see how it sounds, if your having the same problem with lets say a cd player or mp3 then the speaker itself is faulty.
Sep 15, 2007 | Logitech X-230 Computer Speakers
54 people viewed this question
Top Edifier Audio Players & Recorders Experts
David Payne
David Payne
Robert Graf
IT Solution
IT Solution
Are you an Edifier Audio Player and Recorder Expert? Answer questions, earn points and help others
