Question about Garden
Carburator removal I cant figure out how to remove the carb from the saw. can you help?
  • 21 Answers
Tell us what saw it is
Posted on Apr 10, 2014
4 Suggested Answers
  • 154 Answers
SOURCE: throttle linkage came loose from carburator, how do
2 very small screws
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: need to change carburator how do I get it out?
depends on make and model of saw but the saws i use all you do is remove top cover to get to spark plug and the carbs rite there and easy to get to. what make and model is it and ill give you more detailed answer
Posted on Jun 05, 2012
  • 2239 Answers
SOURCE: poulan 2150 saw will not start.
Many saws today have a alluminium key moulded into the flywheel, if the key has sheared the timing will be out and it will never start, remove the flywheel and check the key.
Posted on Jun 07, 2012
Husqvarna K750
sounds like a plugged intake port. remove carburator and cycle cylindar to lowest point, pathway to cylindar interior should be open
Jun 18, 2014 | Saws
Changing my fuel line on my husqvarna141 chain saw and after pulling line out cant figure out where it threads back in to tank
The 141 uses a a very small bore fuel hose, it feeds through the top of the crankcase under the carb, and into the top of the fuel tank, it is not easy to do without removing the fuel tank from the crankcase. To remove the tank, start by removing the air filter held with two screws, remove the two 8mm nuts securing the filter back plate and remove, remove the two 7mm studs securing the carb, and the two cross head screws securing the carb support plate, remove the carb and throttle wire, now remove the four screws securing the starter cover ( these screw into two of the anti vib mounts ) turn the saw over and remove the 4mm allen screw securing the chain catcher at the front corner of the saw, remove the single cross head screw at the rear top corner of the saw and remove the plastic orange cap, the tank will now come away with the top handle as a unit, you can now see and fit the fuel hose.
Oct 18, 2012 | Husqvarna Chain Saw 20" Bar
Need to change carburator how do I get it out?
Jun 05, 2012 | Garden
Carburator removal partner k 750
Remove the covers and the air filter, the screw heads are Torq 27, with the covers removed, insert a Torq 27 tool through the small hole in the black air filter housing ( close to the back of the cylinder ) and undo the screw that goes into the cylinder, now grab the air filter housing and pull firmly toward the back of the machine, it will come away as an assembly along with the carb, lift up far enough to un clip the throttle rod from the trigger, un hook the fuel hose from the carb, you will now have the assembly away from the machine.
Jun 04, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
Cant start my craftsman leaf blower
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can, agitate it to help the gas disolve any clogs.
Clean the ports with the spray cleaner to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 16, 2011 | Craftsman Garden
I had to replace the fuel lines on my craftsman 32cc weedwacker. I removed the throtle line from the carburator and now I can't figure out how to replace it. I would appreciate any help offered.
There should be a little hole on the carb linkage that is usually triangle shaped and the cable has a little "S" looking linkage on it work it into that hole on carb.Good Luck...
May 06, 2011 | Garden
I have a craftsman (poulan) 16inch 2.0 chainsaw. It will start at full throttle and rev up and then die. I have put a carb kit in it, replaced the fuel line and filter and replaced the reed valve and...
f your saw is like mine there are 2 adjustement screws next to the carburator one is high rev the other is idel adjust these screws might help.
Jun 18, 2017 | Craftsman Garden
Poulan PP446T Pole Saw. Will run only if choke is fully closed. Open the choke and it stalls. Have replaced the fuel filter, cleaned carb, installed carb kit. Cleaned gas lines. Good gas mixture(other saw...
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Jan 22, 2010 | Poulan Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
