Question about HP Office Equipment & Supplies
Printer error message
Error message ink cartrage empty and expired when using replacement ink cartridge on hp officejet pro 8500 aa909g series?
    New Friend:
  • 35 Answers
Is this an OEM ink jet cartridge -meaning was it made by HP and not a refill. There is a microchip on the ink cartridge that the printer logs how many times it has used that cartridge and how many times the print head is cleaned. If this chip gets dirty or if the mating side has ink or paper dust on that side you can clean it with isopropyl alcohol. If it was a refill or a generic cartridge the chip might not be programmed or it is dead. There is no sensor that detects how much ink is in a cartridge.
Posted on Mar 31, 2014
SOURCE: ink cartridge
I did try the battery removal (lower left-Inside on motherboard extention) and it didn't work. Then did a soft reset and power down with the batery removed. powered back up (Still no battery) Powered down, reinstalled the battery, powered up and was
able to print. No expired message at all!
Posted on Jun 05, 2008
  • 5476 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
  • 1218 Answers
SOURCE: HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Posted on Sep 06, 2010
dj_relly999
  • 4070 Answers
SOURCE: HP Officejet Pro 8500 wireless- Is there a print
Hi! Please try to unplug the unit from power source and press/hold the power button while unplugged to reset the system. This can be just a system failure which needs to be resetted. After 10secs. plug the printer, turn it on and observe how it goes. Hope this helps and thank you for using Fixya!
Posted on Oct 09, 2010
  • 117 Answers
SOURCE: HP officejet Pro 8500.
Here are some steps can help you.
Use only New Original HP ink
Restart the printer
Rreseat the ink cartridges
Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
Restart the printer.
I hope this will be able to help you resolve the issue.
Thank you for choosing Fixya.
Posted on Mar 16, 2011
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I refilled HP 8500 cartridge but printer (Officejet Pro still thinks cartridge is empty. How do I reset ink level?
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 03, 2013 | HP Officejet Pro 8500 All-in-one -...
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
Restart the printer
Mar 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have all my color cartrage expired and only installed the black one. Can i print?
Yes, you may print with only black.
it will give a message that : Ink Cartridges Empty -
simply click on: Black Only button.
then you will be able print in black only.
Jan 21, 2010 | HP Photosmart 3210 Printer
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
