Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wtw6400sw2 the machine won't fill with water...it starts to fill and then immediately spins it out
    New Friend:
I had a similiar issue last week. Had to do with drain pump parcially blocked. Search on drain issues. Coins get into the pump area and mess things up. I searched utube and found video on how to open up the washer.
Posted on Mar 29, 2014
  • 125 Answers
SOURCE: whirlpool washing machine
You could have a hole in the pump. Check to see where the water is coming from after removing the cabinet, or tip the machine back.
Posted on Jan 10, 2008
lenwest
  • 150 Answers
SOURCE: will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
  • 13 Answers
SOURCE: Washing machine will not start the spin cycle. It
check to see lid switch is making contact... when you close lid it should push down on a switch ..try pushing this down lightly with a pencil
Posted on Oct 16, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Macmarkus
  • 2605 Answers
SOURCE: Started a load, and the
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get a solution for the issue you are inquiring about on the Whirlpool washer...though the complete number would help and should be on the tag inside the door opening of the washer for front-load and under the lid for top-load.
You've haven't specified if this is a new washer or recently installed, or perhaps it's just new to you, but here`s what I find is most common when dealing with the symptom you`ve described ( as long as water isn't filling "overfilling"...then there may be other issues )
I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far.
If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height but not more than 90" or so )
i.e.
I realize the print there is small, so I've typed it out here...
**The standpipe drain requires a minimum diameter standpipe of 2" (5 cm). The minimum carry-away capacity can be no less than 17 gal. (64 L) per minute. A 2" (5 cm) diameter to 1" (2.5 cm) diameter standpipe adapter kit is available. " The top of the standpipe must be at least 39" (99 cm) high and no higher than 96" (244 cm) from the bottom of the washer...not the pedestal if applicable**
Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon.
Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there, but you need to reply so I know. Please provide the model number when doing so.
Thank's for coming to FixYa and good luck.
Regards,
Macmarkus :)
Posted on Aug 21, 2011
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Water won't stop filling the washer
water fill valve is probably stuck open. see if you can find a blockage or just replace it
Feb 03, 2012 | Kenmore HE2 Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Jun 14, 2011 | Washing Machines
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
44 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
