Question about Acer Aspire 3610 Notebook
Remove Middle cover
Does any know how to Remove the Middle cover
  • 90 Answers
I posted the instructions to your last thread...
link here -
decent tutorial...
Posted on Oct 31, 2007
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
Cannot remove gas tank on '11 blackline harley
Gently remove the "Bar and Shield" logo in the middle of the cover, then the final nut, that holds the cover will be exposed.
May 14, 2012 | Motorcycles
I have one pink, one green, and one yellow spec of light almost directly in the middle of the screen. How or why did this happen and how can I fix it?
This set (model indicated) has 3 picture tubes.
I suspect it arced or popped and all three now have a burn mark causing this problem---simple way to prove it:
Remove back cover and cover one of the three large lens(green is middle one) and turn set on----if one of the specs is gone---that tube is burnt---cover lens one at a time and each will vanish.
BAD NEWS----cost to remove/replace all three is too much--AND SOMEONE WOULD have to find and repair the problem that caused it or it will just repeat it again.
Let me know if you have questions.
Jan 27, 2012 | Hitachi 53UWX10B 53" Rear Projection...
I am tring to remove the hard drive from a gateway 610xl desktop system. Do you know where I can get instruction on how to remove the hard drive?
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
"Stroke the front left corner lightly, singing a lullaby, then flip it
over and scratch at the furry spot in the middle."
Feb 25, 2011 | Gateway Media Center 610XL PC Desktop
2004 avalanche driver door windor will not work,liketo know how to remove door panel
there are 3 bolts, one behind cover at door handle just pop cover off with small screw driver. the other 2 are behind cover at arm rest handle, just pop that cover off also. the remove door lock button by prying out on little square in middle of button. once youve done that just stick screw driver between panel and door and pry out . there are plastic clips all the way around panel sucureing it to the door, they just pop out. thats it.
Apr 08, 2010 | 2002 Chevrolet Avalanche
Can I install a 3 prong dryer power cord versus a 4 prong one and will it work?
yes,is your wall plug 3 prong?remove the small cover off the back of the dryer,you will see 3 screws,remove the 4 prong cord,all you have to remember on the 3 prong is the middle wire on the cord goes to the middle screw on the terminal block, mount the other 2 one on each side and your done,let me know how you do-mike
Apr 21, 2009 | Dryers
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
I need to remove the crank case pulley in a 2003 malibu to place a new timing cover and need to know how to remove the crank case pulley
should have 3 or 4 bolts in the middle of pulley and just remove big bolt in center of pulley. skould fall off.
Jan 01, 2009 | Chevrolet Malibu Cars & Trucks
Acer Aspire 3610 Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
