Question about Seiko Watches
841068 any value?
Serial number 1841143. wonderin value.. not working right now. its in fair condition. how much is the value
no name or details as to what it is and if it is not working now then the value will be zero
Feb 22, 2016 | Watches
Value/ year made
The year made cannot be determined from the SN. Since the '50s Bulova used a 2 character date code, usually below the SN. The letter is the decade, the number is the year. For example, M4 is 1964, N6 is 1976, O5 is 1985, etc. As to value, if it is from 1960 through 1976 (M0 thru N6) it is a "true" Accutron, with a tuning fork movement, is collecrible and valuable, and the actual value depends on which specific movement and which case. Some 1977 (N7) Accutrons are akso collectible rtuning fork watches, but some 1977s are Bulova's first quartz watches, and of no value. Bulova eventually went mostly automatic (self-winding mechanical movement) with their Accutron line. Those are well-made, mid to upper-mid level watches, and of no particular value beyond that of most any good used automatic. Note, however, that there have been numerous versions of the automatic Accutrons, some fancier and nmore expensive than others, and, s ith any good watch, original cost will have an effect on value as a used watch. For example, that retailed at, say, $500 new in 2009 will be worth more today than one that was $250 new in 2009 (assuming comparable condition). There are also now some Accutron IIs, which mimic, in looks and the sweep second hand, the original tuning fork Accutrons. However, while they are well-made watches, they are just another nice quartz watch.
Jun 02, 2014 | Accutron Swiss Watch by Bulova 26B44
Watch by serial number
value is only what someone would want to pay for it at that moment. Sentimental has no market value...
nothing available in a brief internet search. I would take it to a watch/jewelry shop for inspection/insurance evaluation. Understand insurance/replacement value is always more than actual street value
Dec 30, 2013 | Watches
I need a valuation on a ladies gold movado watch. Serial number A63165
Hello there, the serial number on a Movado watch is usually unique to each watch and therefore a watch cannot be identified by that. Here is a picture of all the gold ladies Movado watches which are presently available. I have numbered them 1 - 8 accordingly.
1 and 2 are both tagged the Amorosa and are valued at $895 and $1395 respectively.
3 and 4 are both tagged the Concerto and are valued at $2495 and $1495 respectively.
5 and 6 are both tagged the Bellamoda and are valued at $1495 and $1095 respectively.
7 is the Harmony and is valued at $895
8 is the Rondiro and is valued at $1495
If your watch is not on the list above then you might want to send it to the nearest Movado authorised dealer to confirm if it is original or a knock off.
Hope this support has been helpful?
Thank you for visiting FixYa
Sep 10, 2011 | Watches
I got a diesel DZ7149 digital watch with the wrong instruction booklet, the date shown is correct but the time is wrong. the instuctions I have found on line for this model aren't working for me! I can...
1. Press and hold the "SET/EL" button until the display changes to "LIGHT OFF" 2. Press "MODE" until the date section of the display reads "HOUR". Use the "LAP/RESET" button to decrease the value and "ST/STR" to increment the value 3. Press "MODE" to adjust the minute value and then the second value 4. When finished, press "SET/EL" to return to the normal mode
Dec 29, 2010 | Watches
I have ladies wisrtwatch that was gave to me by my grandmother. it is a soverign 21 jewels and i would like to know if is value or not.
mcdevito75, It should have some COLLECTOR value, specially if it runs and keeps time, see a small watch repair shop for an evaluation or, check online, type in your watches name and value in your serach from your home page.
Sep 29, 2010 | Watches
I WOULD LIKE TO ITS TRUE VALUE
mcdevito75 here, Many factors figure in the value of a watch, Of course you have a NAME watch Longines which helps a great deal, First, if the hands are thick, the watch is before 1969, if they are thin, anywhere after 1969, Original strap or band conts, a good, good replacement band is ok. the appearance of the watch, no scratches opr buffing, scrapping on the caseing, no scratches or cracks in the crystal (glass) of course being vintage there will be some evidence of age, and lastly time keeping, if your Longines works well keeps time all day, I estmate it"s value, anywhere from $125.00--------- $200.00. You can also check a small watch repair shop in your area or jewelery shop, they will usually give a rough estmate of value for free.
Jul 17, 2010 | Longines 10K Gold Filled, Manual Wind...
I'm trying to find out what is the current value for a Gucci 3800L ladies watch
mcdevito75 here, Without seeing the watch itself, very hard to tell, the age and condition and of course how well it"s working all count towards it"s value, although GUCCI is a powerfull name in watches all the mentioned factors count toward any watches value. I would figure your Ladies GUCCI watch is valued any where between the $250.00 $350.00 range. Check with a local Jeweler in your area also, for your watches value.
Jun 22, 2010 | Watches
Ned to know retail value
Hard to say without knowing anything about the watch. Here's a link to a good article on valuing your watch. Good luck!
http://www.timezone.com/library/archives/archives0095
Mar 12, 2010 | Watches
American Waltham pocket watch
Ebay often has these for sale; one I also inherited in an 18K gold 'hunters case' (closes from and back) even though perfectly working after a retired jeweler brought it back to life, turned out to be more valuable for its case than anything else. I've seen similar at swap meets/flea markets in plated cases for as little as $70 and still ticking.
Jul 25, 2009 | Watches
Watches Logo
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
