Question about Mitsubishi WD-65732 65" Projection HDTV
Flashing red status light
Sounds like a fan is running
    Scholar:
  • 195 Answers
And a bulb is NOT firing. Try a new bulb..NOT a neoulx one though !!
Posted on May 08, 2014
2 Suggested Answers
  • 31 Answers
SOURCE: Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Posted on Apr 24, 2008
Will a evaporator fan not running in the freezer keep the compressor from coming on. I have a 9 cf. Refrigerator in my camper. But when I turned it on the fans not turning and the coils aren't cool....
does the fans have capacitors if u are having to manually spin them it sounds like the caps are faulty. as for the compressor that will still run even if the fans arnt working it sounds like you have a few issues with the fridge
May 22, 2014 | Refrigerators
Refrigerator not running at all but freezer works
It sounds like your fan may have an issue. If the freezer is still working, and you think the fridge is not running. It sounds like your not hearing the sounds your used to hearing(a fan). Which makes you think its off when its really running and trying to cool. Lmk if you need more help or have any more details! See if you can hear the comp running behind the fridge!
Aug 04, 2013 | Amana Refrigerators
When running the noise sounds like the fan is not working correctly.
when microwave is running the fan sounds like it is grinding
Feb 03, 2013 | GE JVM3670 Microwave Oven
When I turn the heater on, the motor sounds like it wants to turn but there isn't any heat coming out
the fan will run whether or not the heater core is getting warm, it does not care. you can hear the fan run, sounds like a fan running. if there is air coming out the vents and you hear the fan running, then the problem lies with the heater core.
Dec 16, 2010 | 2004 Mitsubishi Galant
The ac is not fully turning on. It sounds like the compressor starts to run, but the fan does not and eventually turn off. With the unit off, i turn the fan on and it sounds like its trying to run but its...
The first thing you should do is make sure the fan turns freely by hand. If it does then check the capacitor and replace it if it's bad. If the fan doesn't turn freely then you may need a new fan.
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
When i turn the car off it sounds like a fan keeps running but it is not the fan
there is a cooling fan that cools the radiator that still runs after the car has been turned off
Nov 04, 2009 | 1996 Chrysler Sebring
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
Xbox cooling fan sounds louder than normal
Yes, the cooling fans are commonly loud. Your xbox has a sensor on it when the CPU and GPU heat up, the rear fans suck more air out by turning up the rpms the fans run at.
Feb 24, 2008 | Microsoft Xbox 360 Console
Fan or motor contantly running and howeling
It really sounds like you need to replace the evaporator fan motor if it sounds like an a/c fan (if it sounds cyclic, metal on metal, screeching, or even like a light aircraft then the bearings are probably failed). The only addition I would make to this is when checking the fan motor with the back cover off you check for any undue ice build up on the coil which may be causing the howling (TO RULE THIS OUT). Hope this helps.
Aug 08, 2007 | Hotpoint HSS25GFP Side by Side...
Mitsubishi WD-65732 65" Projection HDTV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
