Question about Dishwashers
I HAVE A BOSCH DISHWASHER MODEL NO SGS65L22GB/07 WHERE THE HANDLE IS , I CAN GET A SPARE PART BOSCH CAT NO 00449039 BUT I DON'T KNOW HOW TO REMOVE THE OLD FACIA OR FIT THE NEW ONE LOOKING AT IT I THIN
I HAVE A BOSCH DISHWASHER MODEL NO SGS65L22GB/07 THE FACIA IS CRACKED WHERE THE HANDLE IS , I CAN GET A SPARE PART BOSCH CAT NO 00449039 BUT I DON'T KNOW HOW TO REMOVE THE OLD FACIA OR FIT THE NEW ONE LOOKING AT IT I THINK THE FACIA JUST UNCLIPS
  • 409 Answers
SOURCE: Bosch Exxcel Dishwasher - manual please?
hi there,
no problem. the model # is usually located on the inside rim of the cabinet. open the door and locate the sticker itself. i will also need your e-mail address, so i can e-mail you the pdf file.
Posted on Nov 05, 2008
SOURCE: Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Posted on Feb 21, 2009
micromaster
  • 3614 Answers
SOURCE: bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Posted on Jul 08, 2009
  • 10865 Answers
SOURCE: remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Posted on Aug 02, 2009
SOURCE: where is an Aqua-stop fitted in a dishwasher?
In the water inlet hose close to the valve on your supply end,its encased in a big ( 2") plastic housing with a brass fitting.
Hope this helps.
Posted on May 21, 2010
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
I have a bosch dishwasher that shows an arrow displayed on the floor. What does this mean? MODEL SHP7PT55UC/07
That is a time light. It is a Bosch feature that shows what the machine is doing.
Jun 19, 2016 | Bosch Dishwashers
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Where is the float on bosch silver edition?
Hi, This model could well have two systems that will let it fill. One will be on the left hand side as you look at the dishwasher which will require you to remove the side panel. Start with this first as if it is the later version then it will be in the bottom of the dishwasher which will require you to remove the side panels to get to it. The switch in the first method will be a small micro swith and the other will be a large pressure switch located in the bottom. I would think it will be the first method.
Look at it and let me know how you get on.
Feb 27, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
Top Dishwashers Experts
