Question about Apple iPhone Smartphone
How do I remove unused iphone apps
I have apps that I don't use
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Hold your finger on the app to be deleted until it shakes, in the top left hand corner is a cross, press it and it will prompt you to delete it. Also if you double click the bottom button it will show all applications running, you can simply slide the pages you are not using upscreen fast and it will close all running pages that will slow down your phone.
Posted on Mar 29, 2014
3 Suggested Answers
  • 85 Answers
SOURCE: how to remove old e-mail address in app store in apple iphone 3g
you can do this in the new version of itunes.
Posted on Jul 13, 2009
  • 13 Answers
SOURCE: How can you delete iphone apps if you don't use them ever?
You May choose to connect with itune and delete all apps required else double click on app and click delete.
Not so tough Job. Hope it helps
Posted on Apr 01, 2013
I had my new iphone 6s stolen
Google how to find mybiphone6...o believe the find my phone app is pre installed on the newer phones. If not then there is no way to locate it. All you can do is have your service provider blacklist it. This makes it unusable for anyone else
Aug 29, 2016 | Apple iPhone Cell Phones
Tip
How To Save Battery On Your iPhone or iPod Touch
<p><span><span> </span>Is your iPhone or iPod Touch's battery level always depleting quickly? Do you not have enough juice to get you through the day? Here are some quick tips to conserve your battery life and help you get through the day while you are Facebooking, sending texts, and calling.</span><br /> <p><span><span> </span>First, lets make sure you can monitor your batter level. This is how you will turn on the percentage of battery display.</span><br /> <p><span>1.<span> </span></span><span>Go to your home-screen.</span><br /> <p><span>2.<span> </span></span><span>Open up the Settings App.</span><br /> <p><span>3.<span> </span></span><span>Tap General then Usage</span><br /> <p><span>4.<span> </span></span><span>Where it says battery percentage, make sure the switch is in the on position.</span><br /> <p><span><span> </span>Now that you can monitor your battery life, here are a few things you should continually do to save battery.</span><br /> <p><span>&bull;<span> </span></span><span>Don't keep multiple apps running if you don't have to. iPhones and iPod Touches have multitasking to run multiple apps at once, but this can use a lot of battery. To delete tasks, double tap the home button and then hold down an icon at the bottom of the screen. Once the apps begin to wiggle, tap the X by the app to stop the task (note: this won't delete the app, it will only stop it from running).</span><br /> <p><span>&bull;<span> </span></span><span>Another battery saving setting is not fetching email quite as often, I mean, do you really need to check your email every 15 minutes or hour? Fetching data uses a lot of battery, to disable or not as frequently fetch for data, go to the Settings app again. Go to Mail, Contacts, Calendars then Fetch New Data and set it to Manually so to check email, go to the email app and click the refresh button.</span><br /> <p><span>&bull;<span> </span></span><span>Your iPhone has an adjustable brightness, and a higher brightness wastes more battery, to change the brightness: go to your Settings app. Go to Brightness and turn your brightness down. You don't necessarily need to turn it all the way down(especially when you are in bright lighting conditions, kind of ironic that you need higher brightnesses in brighter environments), but if you are in a pitch black room, then there is no reason to have the brightness above the minimum level.</span><br /> <p><span>&bull;<span> </span></span><span>Another good habit is turning off bluetooth and wifi when you are not using them, to do this, go to your Settings app again. Go to Wi-Fi and turn of wifi. To turn of bluetooth, go to General then Bluetooth and turn it off.</span><br /> <p><span>&bull;<span> </span></span><span>If you don't necessarily use an app a lot or at all, turn off Push Notifications. To do this scroll all the way down on your Settings app, and choose that particular app. This will only be useful on an app that gets information from the internet. In the particular app that you chose, usually there will be a Push Notifications option, and you can disable this, this will help your battery because your iPhone constantly tries to search for data with these on. Also, when installing apps, you can disable this then.</span><br /> <p><span>&bull;<span> </span></span><span>Another good way to save battery (iPhone only) is to switch from the 3g(fast internet)radio to Edge(slower internet) radio. On the iPhone, you have twice as much battery with Edge radio. To change between the two, go to your Settings app once again. Go to General then Network and where it says Enable 3g switch it to off. You can/should do this when you aren't heavily surfing the internet, checking Facebook, or downloading apps. Don't use this with apps that require heavy internet usage.</span><br /> <p><span>&bull;<span> </span></span><span>One final tip to conserve battery is changing the amount of time until the iPhone/iPod Touch goes into sleep mode. If you forget to put it in sleep mode, it will stay on and waste battery in your pocket, etc. To change the amount of time to save battery, go to your Settings app again. Go to General then Auto-Lock and change it to something short such as 1 or 2 minutes.</span><br /> <p><span>These tips will significantly prolong your battery, use them to your advantage.</span><br />
on Apr 19, 2011 | Apple iPhone Smartphone
Iphone 4S model number MF259LL/A having trouble upgrading to iOS 8?
Its a large down load. If you do not have enough free memory it may not work. Delete unused apps.
Oct 15, 2014 | Apple iPhone 4S
Iphone 5 face book, insta gram, twitter and pandora are shaded
The icons are greyed out because the app is unusable while it's waiting to update. The phone can hang up when updating if you're on a slow connection for too long. The first thing to try would be to delete the app and try reinstalling while on a good Wi-Fi connection. If that doesn't work, try powering the phone down completely (hold the power button down until the the red slide shows up) and turn the phone back on. If that's *STILL* not enough, you may need to reset your phone. In most cases, that first step is generally all you'll need. Good luck!
Aug 15, 2014 | Apple iPhone 5
After restoring from a jailbreak the facebook an twitter app have shrunk and are now unusable.
Go to the app and tap and hold on it until it shakes. Then tap the x to delete the app. reinstall from the app store.
Feb 09, 2014 | Cell Phones
Apr 01, 2013 | Apple iPhone 3G
How to setup halliburton email on iPhone
Download the app called as cloudmagic... Works for me in my iPhone and iPad... Choose exchange mail in it.... And everything will set up auto..
This apps for ios and android only....
Apr 06, 2012 | Apple iPhone Smartphone
Can i track my iphone if its been switched off?
The only way to find it (besides looking harder smiley-cool.gif), is to use MobileMe and the "Find my iPhone" app. If you have this app installed, great... you can use another iPhone or iPad to locate yours. If you don't have this app, I'm afraid you're out of luck.
Le me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2011 | Cell Phones
Do I get charged if I remove an App from my iPhone & buy it again
Yes. All iPhone apps are backed up on iTunes, so if you want to remove it, just delete it from your phone. However, the safest thing to do is probably to do is:
  1. Connect your iPhone to your computer
  2. Once iTunes starts up, select your iPhone from the side panel
  3. Click on the Applications tab
  4. Choose what Apps you want to be synced with the iPhone. To remove them, uncheck them
  5. Apply the changes and sync the phone.
If you want to add them later, just go back, check the Apps you want, and Apply and Sync.
Nov 10, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
22 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
