Question about Simplicity Garden
Simplicity 16hp Briggs stalls
Engine only runs with the choke on. Have rebuilt the carb. If I shut off the carb the engine runs backfires and stalls after about 30 seconds. Any ideas?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check the slow running jet for glogging, set the mixture screw 2 turns from fully closed and make sure the small filter connected to the fuel tank is not blocked.
Posted on Mar 29, 2014
SOURCE: Stalling Briggs & Stratton engine
Try taking the air filter off ,start the motor and try it. If this works replace air cleaner element
Posted on Oct 05, 2008
bargainbin2
  • 123 Answers
SOURCE: Why does my mower shut off after I turn the choke off?
It sounds like you took the carb off the engine and did not replace the gasket or tore the gasket and it is sucking too much air. Also check to see if the carb and bracket ( if it has one ) are on straight.
Posted on Sep 12, 2009
jdlipscomb41
  • 157 Answers
SOURCE: 646 case tractor with 16hp onan engine if i hold
sounds like the fuel pump is bad or try cleaning the fuel filter and carbarator
Posted on Oct 26, 2009
agent91
  • 2100 Answers
SOURCE: i have a briggs and stratton 14 hp ohv engine on
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Posted on Apr 21, 2010
  • 420 Answers
SOURCE: I have a Simplicity model 1692762 with a 16hp
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
Posted on May 27, 2010
Briggs & Stratton 16HP carb small hose purpose? Have a Snapper riding mower with 16HP Briggs & Stratton16 HP V-TWIN OHV Vanguard, Model 303777 Type 1145-A1 4750 Code 97021011. It started...
Should go to the valve spring access cover. Is the PCV line and keeps engine from building up pressure internally.
To clean the carb you will have to remove it from the engine and give it a through cleaning with small diameter wires run through the ports and blowing out the gunk with low pressure air or WD40's little red tube. From your description, you need to do this as the ports are clogged and not letting proper amounts of fuel through to the engine.
good luck.
Sep 16, 2012 | Tools & Hardware - Others
Simplicity riding mower with 16HP Kohler engine stalls after about 15 minutes. Acts like it isn't getting any fuel, but it will run again later.
I have seen this problem a few times and this may not be the solution however, check the fuel filter. It may have melted and partially closed off the fuel supply. The routing of the fuel hose will cause the inlet end to bend slightly if it gets too hot under the hood.
Aug 24, 2012 | Simplicity 44in Broadmoor Lawn Tractor...
10 hp b&s engine will not run with choke open
Sounds like your carb needs rebuilt .This condition is caused by blockage of ports and jets in the carb .Running a fuel stabilizer will help prevent this .
Feb 13, 2012 | Briggs & Stratton Briggs Stratton 6200...
My briggs vanguard v-twin 16hp after initial start up this fall started leaking fuel from the carb into the cyl. and into muffler. The jet is seated and not dirty. It leaks somewhere else in the bowl. ...
The solenoid on the bottom is a fuel shut off solenoid to prevent backfiring if shutting down engine with the throttle still open. If you're leaking fuel into the engine, the float is not closing the needle valve in the carb. remove fuel bowl and replace float, and needle valve with seat.Be sure to blow out all fuel passages
Oct 15, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
My intek 18hp will only run with choke fully closed.please advise possible problem &solution .the throttle seems to have little impact on the running of the engine
Hi and welcome to FixYa. It sounds like the metering jet in the bottom of the carb throat is clogged.
1st turn off the fuel supply
You will have to remove the float bowl from the carb and then the BRASS jet / orifice. Once removed hold it up to the light.. you should see a pinhole of light thru the jet. No pin-hile = run only with choke. ALSO the nut / bolt that holds on the float bowl has 2 holes in it make sure those are clear.
Before you reinstall the float bowl turn on the fuel and catch it in a spray paint can lid or something similar. It should flow rapidly and stop as you GENTLY raise the float. If no flow then you have a stuck needle and seat or a clogged fuel supply line. Correct same and reinstall the filter bowl. It should run fine after that.
Thanks for using FixYa!
Kelly
Mar 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Choke needs to stay on and engine backfires when
COULD BE A CARBARATOR PROBLEM
YOUR PROBLEM IS CALLED ENGINE RUN ON OR DIESELING THIS HAPPENS WHEN YOU TURN OFF THE KEY AND FUEL IS STILL BEING PUMPED INTO THE CARB. COULD BE DIRT UNDER THE NEEDLE VALVE FOR THE FLOAT
Aug 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Runs for 25 minutes then shuts down like its out of fuel
try taking the plunger off the fuel shutoff solenoid on the bottom of the carb
Jul 01, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
128 people viewed this question
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
