Question about Lenovo Computers & Internet
Dvd drive not show up
Dvd drive not show in my laptop
  • Lenovo Master
  • 3,320 Answers
New drive or existing drive?
Posted on Mar 30, 2014
My dvd drive now shows as bd drive, how can I change it back to dvd drive on my laptop?
Do a system restore to try and correct this before it happened, if no change. Go to www.download.com Type: dvd repair this will fix most problems.
Mar 28, 2012 | Computers & Internet
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
The DVD/+ of My Acer just stopped working
Sounds like the data connection to the drive has been lost. The power connection is still present, though. i would try to remove the drive, and with a light try to look at the connectors on the inside of the computer and also at the back of the drive. If nothing is obviously wrong, blow the area out with air and plug it back in. If this doesn't fix it, start looking for a new DVD drive for the computer. Good luck!
Nov 07, 2009 | Acer Aspire 7520-5185 Laptop
My dvd drive doesnt reconise disks when they are in the drive
2 things that u have to check
1) Is your DVD disks damage so u cannot read it?
2) Is your DVD drive spoil so cannot read your DVD?
To check condition 1), u may try insert other "good" DVD to make sure your DVD drive may read it. If your DVD drive can read other DVD so this mean your current DVD disks are damage.
To check condition 2), u may try load your DVD disks using other laptop. If your DVD show readable on other laptop, then this mean your current DVD drive is spoil or may have poor lens sensibility. Try to clean your DVD drive or replace a new 1 if necessary.
YBC (/\)
Oct 02, 2009 | Acer Aspire 3050-1733 Notebook
I have compaq 738 tu laptop. ''my computer'' is not showing cd-dvd drive in my laptop. how can i resolve my problem?
If you have formatted your laptop without backup then it will not show CD-DVD drive
1) Please update the drivers.
2) Please get the data cable checked, it can also be the problem, in most of the cases data cable melts and disconnects the CD-DVD drive from the system.
Sep 04, 2009 | Tablets & eReaders
R500 laptop doesn't show/recognise CD/DVD drive
you most certainly must change your drive because its defective...
the good thing is that you do not have to open the laptop apart to do it but unscrew just one... screw (!) and pull it out.
all the pc-shops that sell drives for laptops would change it for you at once... just take the laptop with you.
as for the cost, here in greece a dvd-recorder for laptops is about 30 - 40 euro for a SATA type and about 50 for IDE type. In the shop they will see if you need a SATA or an IDE drive when they will take out the old one.
Sep 02, 2009 | Toshiba PORTEGE R500-S5006V INTEL CENT 2GB...
My laptop is not showing me the DVD/RW.
Go to device manager by typing devmgmt.msc in RUN option which u find in START option... after that click on CD/DVD drive and press Uninstall.... after that restart the notebook will install CD/DVD drive drivers...... hope this could help u.
Jul 23, 2009 | Quantum Meridian CD Net CD-ROM Drive
My dvd rom does not show up in" my computer". i cannot play any dvd or cd. my driver agent says that HL-DT-ST DVDRAM GSA-T40N ATA DEVICE is disconnected.
Best thing to try, take out the dvd drive completely from the laptop. Then go ahead and reseat the drive back into its slot and put the screw back into place. Do all of this while the laptop is turned off.
Now go ahead and turn the laptop back on and go into the bios. Once in there it should show you the dvd drive, if it does show it to you then reboot into windows and then the drive should show up into my computer and you should be able to play dvd and cd's again.
If your drive doesn't show up in the BIOS then reset defaults and then reboot the laptop back into windows. If it still doesn't show up in there then you have a bad dvd drive.
Jun 21, 2009 | MSI VR420 Notebook
Laptop not show cd or dvd when i put it
Well, for starters, is your cd/dvd turned on in the bios.  Some but not all computer have a setting for this.  If your cd/dvd drive is removable, shut down the computer, remove the drive.  Reboot the computer and shut it down again.  Then reconnect the drive and start the computer back up.  This will make sure that if your drive is working, windows will redetect it.  You can check device manager to make sure it is not disabled.  If none of this works, you may have a bad drive.  If you really must reinstall windows, you can get an external cd/dvd drive pretty cheap on Ebay.  Just make sure you go into your BIOS setting and change the boot menu to external drive.  I hope this information helps.
May 30, 2009 | HP Compaq Presario C700T
DVD drive not accessing some DVD
the dvd region of your dvd drive does not match with the region code of some of the dvd drive, you can change the region code five times, but its better download the software like region code breaker, then play dvd's.
how do you like the solution please rate it
Oct 21, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
23 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
