Question about Vizio SV471XVT 47 in. LCD TV
Sv471xvt picture goes negative the returns normal after a while. Problem is intermittent
Sometimes this happens at power on other times after tv has been on a while. Kind of a Green and black negative, sound is ok and picture returns normal in a few mins. Happens on HD and non-HD channels as well as video inputs (i.e. DVD)
  • 56 Answers
My Samsung did this and this helped after it died a few days later
https://www.youtube.com/watch?v=8l0AUj8QUkg
Posted on Apr 16, 2014
SOURCE: vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
Posted on Apr 09, 2008
Ajkill
  • 2035 Answers
SOURCE: Vizio VX32L TV changes channels and loses input.
This is the peoblem with on board control chip which ,you need to change the main board itself but if the TV is under warranty you get it done for free or this could company defect...............
Posted on Jun 07, 2008
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
SOURCE: Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Posted on Jan 29, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Posted on Nov 02, 2009
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Feb 25, 2016 | Samsung Televison & Video
Tv has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Televison & Video
Where is the backlight inverter located in vizio sv471xvt?
Larger sets such as the one you have, will have two inverters. They usually are attached to the backside of the LCD panel on the left and right sides. If you don't see them there, then your inverters are built into your power board. If your power boards are either one of these below, then that is the case. If your inverter circuit is at fault, you will have to replace the entire power board.
http://www.shopjimmy.com/vizio-0500-0407-0800-power-supply-unit.htm
http://www.shopjimmy.com/vizio-0500-0412-0800-power-supply-unit.htm
May 20, 2012 | Vizio SV471XVT 47 in. LCD TV
Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Jun 12, 2009 | Sharp LC46SB54U 46 in. LCD TV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Picture looks like photo negative when power is reapplied
the most probable problem is it would be one of the first generation LCD televisions.
if possible try changing the refresh rate of your tv
it may help.
Feb 02, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
Hitachi 23" tv/ toshiba vcr
Sounds like a problem in your VCR IF what your saying is when the screen goes dark and you turn off the VCR then the screen on the tv returns to normal?? Does this happen with the vcr on and the tape not playing?? No Ok you have a problem in the video processor Ic or the circuit but most likly the IC as Ive seen this already twice in a toshiba VCR. No if it happens even when the VCR is on but the tapes not plying and the vcr is sitting, and the screen fades The problem is the on screen disply IC in the vcr. seen this a dozon or so times already. Vcrs no a days are not worth the money to invest Unless you got a really good one from the past, BUT you can by a good on for these times for well under 100 bucks . Good Luck
Jun 06, 2006 | Hitachi 57G500 57" TV
Vizio SV471XVT 47 in. LCD TV Logo
128 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
