Question about Ebac HD880 Dehumidifier
How to take the backing case of a homedry
I am trying to get to the fan as it is making a squeaking noise, i have taking the 2 screws out from the bottom, now i would guess you take the plug of the back, but how does this come of as i have tried many ways but with no luck and i am close to breaking it if i try any harder, many thanks
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Why is my dehumidifier very noisy?
I would guess that some rubber anti-vibration mounts have aged. If so this may allow the cooling fan to move and grate on the fan housing. It is unusual for the hermetic compressor to give trouble but having just said that, on rare occasions the big-end bearing can fail. This would cause a very obvious knocking noise coming from the compressor. Its just a case of carefully opening up the dehumidifier housing and looking to see what is happening. As an aide-memoire one can tape all the screws to a piece of cardboard adding notes as to where they came from. Take care and good luck!
Aug 21, 2014 | Kenmore 54501 Dehumidifier
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
Apr 03, 2014 | Dehumidifiers
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
My dehumidifier makes squeaking noises when running. How do I stop this?
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 02, 2010 | Whirlpool AD40USL Dehumidifier
I HAVE A EBAC HOMEDRY 880 dehumidifier LOOKING FOR A FAN MOTOR THE MOTOR AT PRESENT IS A MAGNETEK UNIVEARSAL ELECTRI LTD 220/240VOLT 50HZ 0.16A impedance protected
Hi, If you are in new Zealand and your 880 model is the NZ 870 model, the fan motor can be got at Carrier Air Conditioning, part # SP-W3035766, for around $105.00.
Mar 20, 2010 | Ebac HD880 Dehumidifier
Replacement fan motor for ebac homedry 880 dehumidifier. fan motor Mod No aa2c6235
Noel
Feb 27, 2010 | Ebac HD880 Dehumidifier
Just replaced fan motor,and blade works fine,been running for 4 days,but no water collected,in container home homedry 660
These are somewhat related to cooling systems so the system may need a coolant recharge like any AC. Check your user guide to see if there is any mention of a need for recharging.
Oct 04, 2009 | Ebac HD880 Dehumidifier
Fan motor making squeaking noise; sounds like bushing failure.
PLEAS IF SOUND REALY FROM THE MOTOR SOME OF THE MOTORS HAVE BEARING CAN BE REPLACED BUT IF IS BUSHING BETTER TO CHANGE THE MOTOR.
Sep 17, 2009 | Maytag M7DH45B2A Dehumidifier
Ebac HD880 Dehumidifier Logo
79 people viewed this question
Top Ebac Dehumidifiers Experts
Bill Long
jasbo
jasbo
NOEL
NOEL
Are you an Ebac Dehumidifier Expert? Answer questions, earn points and help others
